2000 S80 Climate Control wiring diagram?
GeriatricGinger
Year and Model: 2000 S80
Has thanked: 1 time
Post by GeriatricGinger »
Hello,
I've searched and was unable to find a thread that had it, but does anyone have a wiring diagram/pinout for the CCM? My 2000 2.9 was in for service, and came out with a 'dead' climate control. absolutely nothing works on the CCM (no lights, no nothing).
I've done the usual 'tricks' of disconnecting the battery, touching cables, door locking trick, etc. The thermistor is still in tact, even tried the jumper wire trick across the thermistor to no avail.
My state inspection is now dead, and it will not pass with no defrost/blower function, so I'm kinda screwed. $1000+ for a new replacement is not in the cards, as the car isn't worth much more than that.
Thank you in advance,
GG
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
www.volvowiringdiagrams.com
Your need something with a full Group 87 in it, TP3942202 S80 1999 Late Version Wiring Diagrams.pdf should be the same for the CCM.
Active
Past
GeriatricGinger
Has thanked: 1 time
thanks so much, sir!
