1994 Volvo 960 Issues
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
First of all, I don’t own a 9xx series, so, this advice is rather generic...
If the turn signal works when brake is not applied, issue is likely in rear tail light assembly somewhere. My first guess is a shared ground between brake and turn signal. Take a voltmeter and look across affected turn signal bulb while friend presses on brake. I expect that you have some voltage, but not 12v. Assuming that is what you measure, now take a reading between turn signal bulb ground and chassis ground. Is it greater than 0v with brake applied again? If so, ground wire is at fault and can’t support both brake and signal. Clean ground connections. If you get different readings report back on measurements and we can go from there. PM me if needed, I don’t check this specific forum very often since I junked all of my 240s.
- 874 Views
Last post by tomoni40
- 710 Views
Last post by Erpau0732
- 3244 Views
Last post by volvolugnut
- 107 Views
Last post by MasterBashe
- 1639 Views
Last post by Luttrell
