I failed inspection for my driver side low beam headlight.
I checked the fuses and they were good.
Bulbs are good, I hooked the whole headlight up to another xc90 and everything works.
But on my xc90, the driver side low beam headlight doesn’t work but all other lights like parking, high beam work on it.
What could be wrong with it?
Volvo wants 140 to diagnose and other shops said it could cost up to 300. After spending so much on my rear bearings to be replaced, I was hoping to figure this headlight out myself.
Please help!!! Thank you
2008 Volvo XC90 Driver side Low beam Not working Fuses good
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
Do you have xenon lighting or halogen? If its xenon it could be the ballast or ignitor or headlight module.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
jimmy57
- Been thanked: 322 times
Any chance you've had any water leaks into driver's floor? The CEM in on left under dash and the top of it comes out into the cowl area in front of windshield. If the cowl drains or CEM top cover seal fails then the CEM gets wet and lots of different issues result. Headlight failures are one symptom. The fuses need be checked with a meter. Visual inspection doesn't always reveal a fuse that goes open in less than obvious ways.
precopster
- Year and Model: Lots
- Been thanked: 128 times
As above ^^
Remove the kick panel closest to the steering wheel and look up. You'll see a black casing with connectors. That is the CEM. Check all fuses on it.
Water ingress is the most likely failure cause. Blockage of sunroof drain channels is one cause. The rubber seals behind the wiper cowling may have been disturbed.
Knowledge is divine. Everyone knows the importance of education and students strives very hard to achieve their goals from the beginning of their student life.
gcu student portal |
gcu student portal login
- 972 Views
Last post by SuperHerman
- 2034 Views
Last post by Jokerz
- 1189 Views
Last post by shiloh51933
- 799 Views
Last post by BEJinFbk
- 865 Views
Last post by XC90Bob
