Volvo 98 S70 Dipstick Tube replacement and tools required
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Hello, welcome to MVS!
If I remember correctly, you just use a 10 or 12mm socket on the bolt near the top of the dipstick (that holds it in place). Once that's out, the whole thing should pop out of the oil pan with a small tug.
You replacing the o-ring or something down there?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Good old Cali emissions...
Yeah, believe there is an o-ring at the bottom and a bolt at the top under or near the intake manifold - almost identical to the V70 except possibly the part number and fitment.
- wizechatmgr
Yes, including washing your hands afterwards. =)
FlyingVolvo
Very quick replacement. Hopefully new tube comes with an o-ring. If it doesn't you might want to consider replacing it as they get old and can leak.
2023 V60 T8 PE
2023 V60 T8 PE
FlyingVolvo
If you can find an exact fit, sure. If not, clean up and re-use the old one if it's still in one piece. Next time you order something from one of the online parts stores you could get a new one cheap. Less than a dollar for aftermarket, a few bucks for Genuine.
2023 V60 T8 PE
2023 V60 T8 PE
- 5021 Views
Last post by JimBee
- 1815 Views
Last post by chaos26670
- 2739 Views
Last post by matthew1
- 4067 Views
Last post by PapaNoni
- 896 Views
Last post by Bandit123
