My car needs the timing belt changed; it's got a hydraulic tensioner installed currently.
I'd like to be able to take advantage of the longer interval in the future, if that's possible. Does a mechanical tensioner just bolt right up in place of the hydraulic one, or are there other differences that would make this not work right?
1998 V70R: replacing hydraulic tensioner with mechanical?
- atomicthumbs
- Year and Model: 1998 V70R
- Been thanked: 4068 times
I don’t think the systems are compatible at all, jimmy is probably the guy who can answer this.
- Has thanked: 311 times
- Been thanked: 817 times
You can confidently go two timing belt intervals on a blue box hydraulic tensioner (made by Aisin), you've got the longevity issue backwards there.
Every timing belt job: all pulleys, timing belt, mechanical tensioner
Every other timing belt job: hydraulic tensioner
At 200k or when you're just bored: factory water pump.
I once contemplated switching my 98 from mechanical to hydraulic, I know that direction is easy but IIRC you have to change the rear plastic timing cover. Hydraulic's bolt holes are there in my car's block. And the timing belt lengths are different, else it is a straightforward swap.
- atomicthumbs
I'm thinking less about the cost of the tensioner and more about the extended interval for the whole setup, even if I have to change the mechanical one every time. The less work the better.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Why would you do that since hydraulic one is more durable?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
precopster
- Year and Model: Lots
- Been thanked: 128 times
I converted my 1999 V70 to an 850 block (but I kept the 1999 head) afew years back. I documented the thread called "Correct compression testing procedure" viewtopic.php?f=1&t=39074&hilit=Correct ... e&start=10
Not an easy task and best to pull the engine for access as you will need to drill and tap a hole in that centre stub for the tensioner.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Interesting thread.
- 14 Replies
- 7748 Views
Last post by RickHaleParker
- 1249 Views
Last post by jimmy57
- 1542 Views
Last post by precopster
- 16 Replies
- 5132 Views
Last post by theWIFES_S70
- 1457 Views
