Do I need to reprogram my radio? Topic is solved
GMJim
Year and Model: 2008 C30
Post by GMJim »
I recently removed my head unit on my C30 to get the radio AM repaired. Prior to removing it everything worked fine (CD, and FM) except the AM (no sound and wouldn't lock on to a station) and no sound on the Sirius 1 or 2 but the display showed the Sirius XM preview screen as I don't have a subscription. After the repair the AM works perfectly but I no longer have the Sirius XM screen. It's just a blank screen. The repair company can't explain this and said the AM repair is an easy one and should not have affected other features of the radio. Is there a possibility that I may have to have the car hooked up to the dealer computer to re-install the SIrius XM?
Thanks
GMJim
Post by GMJim »
Never mind. Pulled the battery cables to discharge the system and all is well now!
jtopiso
Year and Model: 2009 C30 2.0i
Been thanked: 3 times
Post by jtopiso »
Can you explain how was the AM radio repaired? I am having the same issue.
GMJim
Post by GMJim »
Initially I had a problem with the connector for the antenna. While cleaning the side glass I must have bumped the connector off at the top of the glass and it caused a lot of static and bad reception. After finding and fixing that It worked fine. A year or two later the problem returned only worse and I checked the connector and it was ok but the AM was completely dead. Apparently this is a common failure in these radios. I don't know if there is a repair shop where you are but there is a place called Xemodex (zee-mo-dex) in Mississauga, Ontario, Canada that does repairs to most electronic components for Volvo and other makes. They told me there was a corroded filter that they replaced. How it got corroded is not clear but the radio works perfectly now. The told me they fix components from all over the world.
https://xemodex.com/
jtopiso
Post by jtopiso »
Thanks, I will check the Antenna, and otherwise take the radio to get it checked at an electronics shop.
I think going to Ontario might not be too practical in this case ;)
Regards (from Spain)
GMJim
Post by GMJim »
Yes shipping would be expensive and also the cost to repair the radio was $229 Canadian plus our 13% tax so not cheap but your choices for Volvo radios is limited
