Yard only had a black mirror (hard shell portion) so I want to repaint it. Where's a source of the right paint? Any particular issues with priming the already painted plastic of the exterior mirror housing?
Also the "arm" portion, and the mirror side bezel, are a softer plastic and grey (weird...wonder if the black shell was put on a grey car) has been wind-abraded down to a light grey (primer?). Not sure if this would accept the same paint as the hard shell.
1996 850 need pewter grey paint for plastic (exterior mirror)
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
You can probably still get this color directly from Volvo in a little spray can, but it will be expensive.
I have had good experience with this company:
http://www.automotivetouchup.com/index.htm
I actually got the same pewter color recently for my 850 and it was a pretty good match. They also sell primer for plastic if I remember right.
Dirk
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
What kind of primer for the already-painted plastic housing? Not the filler type for bare metal or Bondo. Do I need to sand the plastic, or use a chemical to soften it?
NEVER OPEN THE HOOD !!!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You don't need a primer for allready painted part....just a light(fine) scotch brite pad to prime the surface for new paint or 2000 grit water sand paper.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 843 Views
Last post by MoVolvos
- 1015 Views
Last post by darrylrobert
- 529 Views
Last post by Sommerfeldt
- 1238 Views
Last post by oragex
- 940 Views
