Right Rear Transverse Arm Mount
Angela1
Year and Model: 1998 Volvo S70 GLH
Post by Angela1 »
I just had the alignment on my 98 S70 checked and the shop informed me my right rear transverse arm mount is broken. Well after much searching through the major parts sites I figured out there is such a thing as a transverse arm and actually located some diagrams that were helpful. I cant find the part. Has anyone encountered a similar situation. Any ideas would be appreciated. Many Thanks Angela
yair
Year and Model: 1997 940 sw
Has thanked: 1 time
Been thanked: 3 times
Post by yair »
It could be the link:
https://www.fcpeuro.com/products/volvo- ... -3516122oe
Or could be the bushing/anchorage, I needed to replace a broken one on my 1996 850 that broke off.
https://www.fcpeuro.com/products/volvo- ... 13-9181014
Better ask the shop to show you, or give you a photo of the mount, and ask them tell you if the mount itself is located on the right, or left side, because the right arm bushing is installed on the left side of the car, and vice versa.
You can check diagrams here:
https://www.volvopartswebstore.com/show ... ct=1229750
yair
1997 940 wagon
2005 XC90
1996 855 Turbo
1995 850 n/a, rest in pieces.
Has thanked: 1609 times
Been thanked: 4064 times
Trailing arm bushing or delta link, or both.
It’s a nasty job for DIY, did one, didn’t like it
Angela1
Post by Angela1 »
Thank you so much will check it out and update. As an aside I can’t say enough good things about this site. Earlier this spring I thought my vehicle was kaput. I’ve learned so much and saved tons with the diy I could manage. The car body still looks great and now the engine is zipping right along. I just have to get through this suspension issue and I should get some great use out of her. Just went over 250,000. Many thanks
We have quite a few PA Volvo people here on MVS, Angela - if you want put your approximate location into your profile we can also connect you to people who have things like scanners and software which can make life easy.
We also pride ourselves on making our site inclusive and friendly to all.
