code 00089 Fuel Pressure Regulator 1 Performance
adrian22
Year and Model: s60 2006
Post by adrian22 »
xc70 125k miles got engine check light w/this code several times after it was erased-car performance and mileage is not affected.No other symptoms detected-car runs normal--SHOULD I IGNORE IT?
I suspect fuel filter is clogged-it is the original filter that has 125k miles-
Big question can this filter trigger this code?
I changed fuel pressure sensor at the end of fuel rail but the code still coming back after erase
My research shows:
P0089 trouble code definition
P0089 is Fuel Pressure Regulator 1 Performance, indicating a problem in the fuel pressure regulator system.
What causes the P0089 code?
Failed fuel pressure regulator
Clogged fuel filter or screen
Restricted fuel lines
Fuel pump output not meeting specifications
adrian22
Has thanked: 1609 times
Been thanked: 4065 times
Fuel filters on these cars last a long time
Measureand monitor the fuel pressure at the rail to see how the fuel delivery system is operating.
I’ll try to find specs
adrian22
Post by adrian22 »
I am confused regarding this part
Amazon is listing 2 different part names and prices for same part # and shape
which one should I buy to fix my P0089 code?
https://www.amazon.com/s/ref=nb_sb_noss ... ure+Sensor
adrian22
Use a primary reference for getting parts
VIDA
Tasha Volvo
Lisle Volvo
All have OEM PARTS engines
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Buy the cheaper one. Those are the same part but one seller is just charging more.
adrian22
Post by adrian22 »
I got the exact part number same Bosh as the old one but still not fixed the engine light code P0089
adrian22
You need to measure the fuel pressure at the rail to evaluate the performance of the CEM, the PEM, the fuel pump, filter and delivery components. If you just replace parts, your total cost of repair will be between $100-900
adrian22
Post by adrian22 »
I never used a fuel pressure gauge before and not sure if there is a Volvo specific kit or any universal kit will work
Also please indicate where to hook up the gauge hose in order to take the measurements ?
I saw this kit on the ebay -do you think will work for my xc70 2005?
https://www.ebay.com/i/142437148601?chn=ps
adrian22
jimmy57
Post by jimmy57 »
That kit will work but you find similar at Harbor Freight for similar price if you use a 20% off coupon. The 20% off are online, Google it.
The fuel pressure port is towards the front (serpentine belt side) just behind and above upper radiator hose. Looks like a tire valve and should have a grey or blue cap but the original cap could have been replaced by any tire valve cap.
The one labled release valve is it.
fuel pressure.jpg (62.38 KiB) Viewed 6249 times
adrian22
Post by adrian22 »
THANKS jimmy57
you helped me many times with my old 850 cars and now with xc70...you are fantastic-many thanks
adrian22
