I am trying to find a definitive answer amd not having much luck so far.
Does anyone know if a manual transmission s70 can be flat towed behind an rv with all 4 wheels on the ground? Since the manual transmission is splash lubricated my assumption would be yes it can be. However ive only found one article online to back that up and i am looking for a definitive answer either way.
If anyone has experience doing this could you please provide details on your setup and what you did for your base plate? It Looks like it would need to be custom as all i can find are universal ones online. I would think attaching to the subframe mounts up front would be more than sufficient but would Love to hear from someone with experience doing this.
My car: 98 s70 t5m
Flat towing s70 t5m all 4 on the ground
Socalboostin
- Year and Model: 98 s70 t5m
LOB
- Year and Model: 855 GLT 2.5T
- Has thanked: 10 times
- Been thanked: 16 times
Living in a country where manual drive is the norm I can tell you that towing with all 4 wheels rotating is not a problem, at least as long as you keep the gear in neutral.... The gearbox won't spin and overheat while in neutral. Don't really understand what you mean with "base plate"? Anchor point for towing? There's a dedicated anchor for a tow line in the front bumper. I'll guess that's sufficient.Socalboostin wrote: 08 Nov 2018, 00:09 I am trying to find a definitive answer amd not having much luck so far.
My car: 98 s70 t5m
Speaking about towing. Remember to turn the key to third position BEFORE towing.... My 240 was slaughtered by some low-lifes outside of Stockholm two decades ago. The car was stone dead and I forgot to unlock the steering wheel going to the junk yard... Luckily the guy towing me noticed my frantic expression an frenetic wayving with my arms.
A used tow dolly About $500-600 is the best solution
You can flat tow a FWD manual transmission car till the cows come home.
Don’t put anything in the car that can bang the shifter into gear.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I would use a dolly. Saves on front tire wear and IMO is a bit safer. Then you don't have to worry about the transmission.
Knows enough to be dangerous
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
yes you can
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I would also use a dolly for mostly the same reason except the transmission really doesn't care. It gets exactly the same lubrication as when driving.WhatAmIDoing wrote: 08 Nov 2018, 09:16 I would use a dolly. Saves on front tire wear and IMO is a bit safer. Then you don't have to worry about the transmission.
- 3263 Views
Last post by bmdubya1198
- 899 Views
- 3279 Views
Last post by SuperHerman
- 18 Replies
- 4668 Views
Last post by manyvolvosmoveme
- 1064 Views
Last post by E Showell
