Looking at a 2000 V70, supposed to stall
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
I've been looking at a low mileage (110K) 2000 V70. Owner reports that it occasionally stalls, then restarts. I have not seen this actually occur. He tells me that he had codes pulled and it indicated a bad TPS, along with a lot of other codes. Does the TPS seem the likely culprit? I think it significant that the car had sat for a few years before he purchased it. It also vibrates from the rear wheel driveshaft, I suppose I will just pull it.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
- Has thanked: 2205 times
It could be the TPS, but worth swapping the fuel pump relay first. Other codes can get thrown when car shuts down. Depending what the codes are, I'd consider noting them, then clear them all and run the car with a replacement Volvo fuel pump relay and see what happens.
You don't say it clearly, but it looks like you either have a V70XC or V70 AWD as you mention the prop=shaft vibration. Pulling would be the easy out and then decide if you want it re-built (Colorado Drive-shaft) and re-install.
Bigger issue if it is an ETM issue (Xemodex or likes re-build) or possibly a fuel pump failing as AWD are a big job to do compared to a FWD.
- Been thanked: 4069 times
Yeah, you have to clear codes and see what comes back. TPS is unlikely culprit
Faust
abscate wrote: 08 Nov 2018, 21:34 Yeah, you have to clear codes and see what comes back. TPS is unlikely culprit
Will disconnecting the batery for an hour clear the codes, or do I need an OBD reader? Too bad about the TPS being unlikely, I happen to have one.
2004 V70
That should do it. Be on the lookout for the seller who has figured out his MM electronic throttle body (ETB, ETM) has pooped the bed and is looking for the sucker to unload the car.
Make sure the ETS light lights up on start up , and the EZtM clicks and whines for 8 seconds on key on.
Faust
"Make sure the ETS light lights up on start up" It does.
I finally took the car for a test drive. Generally a pretty nice car, as you would expect with 110k miles. The idle does hunt a bit between 800-1100. Twice while I was driving it, it stalled. Pulled over and it started right up. Seemed to run normally otherwise. I pulled into the local O'Reillys and had the codes pulled. The price is quite right, but I would like opinions as to whether I should just run away from it. Here are the codes. Many came up "no definition" so I have Googled them for a result
P0743 Torque Converter Solenoid.
P1550 No Definition ABS?
P1238 No Definition Turbo Control Valve?
P1171 No Definition Fuel Trim Upper Limit?
P0121 TPS
P1618 No Definition
P0134 O2 Sensor
P0121 TPS
P1618 No Definition
P0134 O2 Sensor
2004 V70
Look at all those vacuum hoses and look for leaks and splits. If you can't find any, it is probably in the ETM
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
Personally, I’d consider general condition and documented maintenance as more important in your decision whether to buy car or not. The stalling issue will be fixed for a few hundred worse case and some short term aggravation. If you plan to keep it for another 100k mi, this is insignificant. The other codes may or may not be significant, the stalling can cause false false reads.Faust wrote: 10 Nov 2018, 11:00 "Make sure the ETS light lights up on start up" It does.
...The price is quite right, but I would like opinions as to whether I should just run away from it. Here are the codes. Many came up "no definition" so I have Googled them for a result
Faust - were those the stored codes or codes after clearing?
Reset the CEL and see what pends.
Get a mirror and look for a white label or yellow on the ETM, at 110k, Ill bet it is a white label
