95 850 - No forward gears
slayer7
- Year and Model: 850 95
Went out to drive the 850 yesterday and there's no forward gears, only goes in reverse. When putting it into D or any of the manual forward gears it acts like it's in neutral, doesn't catch or anything. Reverse seems to work fine. Played with the Economy/Sport/Winter switch, even disconnecting it, did nothing. Fluid is in proper range, a little dark but was changed about 20-30k ago. Any ideas?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Orange arrow ON or flashing?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2212 times
- Been thanked: 1853 times
Check both your axles are fully home. I made a mistake swapping an axle and it was not fully home. Lost all drive but no orange light. Mind you I would expect that to affect the reverse too, but never tried reverse at the time.
- misha
Without axles fully home he wouldn't have a reverse neither,Neil.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
slayer7
Thanks for the replies. The orange arrow is ON when in the manual 2 gear positions below D but not in Drive. Someone had also suggested that it might be a problem with the PNP switch so I followed the walkthrough here to remove, repair and replace it but unfortunately that didn't help either.
- Has thanked: 1613 times
- Been thanked: 4075 times
Ouch. Unless you pull the trans, the only market will be in the Bronx.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Others might know more about the relays inside the little box on the lower front of the transmission. It's kind of hard to get the cover off their housing, but apparently doable. The relays themselves I seem to recall are not expensive and fairly easy to change once you get access. I haven't tried it. Your symptoms do seem to suggest that might be your problem. If a relay gets power when you shift, but doesn't activate the clutches, then it's no go.
slayer7
Abscate - your reply was both infuriating and hilarious at the same time.
Jimbee - I found a procedure to check the TCM for codes. I will try that to see if it indicates any trouble with the relays. I've been kinda wondering about an electrical issue since the thing was working just fine when parked and then the next day, suddenly wouldn't go into gear with no other warnings.
That’s a good sign slayer...If it went out real quickly I’m with you that’s it could just be an electrical issue.
One of my favourite movies
“ for 20 bucks, he’s out of your life forever”
And, of course....
“ Now youse can’t leave”
And, of course....
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Have you tried to press the WINTER button to see if it will start rolling in 3rd gear?
- 321 Views
Last post by firstv70volvo
- 1142 Views
Last post by Ozark Lee
- 1707 Views
Last post by rspi
- 831 Views
Last post by rspi
- 1435 Views
