Im having a hiccup at 2000-2500 rpm range on my 1998 v70r
Im having a hiccup in my 1998 v70r in the 2000 to 2500rpm range only..any other time its fine..it doesnt do it when completly cold..2 mins in if i hit that rpm range to shutters or hiccups..anyone got a cure or idea of whats going on? No codes show up at all..
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
How old are your ignition components: cap, rotor, wires, plugs? Could be fuel pump relay on its way out (especially KAE). Maybe the ECT is reading wonky. MAF sensor is also a likely suspect. Also check all induction and vacuum lines, as small cracks can cause poor performance.
Knows enough to be dangerous
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
when there is a distributor involved the rotor and contacts in cap for the plug wires are not in alignment when timing is advanced or retarded a lot. The gap the spark jumps is larger and it will jump across a track in cap to another plug wire contact if the correct plug wire has resistance. Required firing voltage is not a constant and is higher for richer mixture. When the voltage builds to ionize the gap between plug electrodes and that is compounded by plug wire issues the current will find a lesser required voltage path.
Does it do this when accelerating or at steady cruise in that range
- WhatAmIDoing
That would point to worn / dirty components as outlined above.
jimmy57
Fits with bad wires and tracked cap. You can probably see if it you remove distributor cap. Replace rotor too as those can track through rotor and ground to driving shaft.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
How old are the ignition components?
- 1905 Views
Last post by graysonboycie
- 383 Views
Last post by BYork3
- 7508 Views
- 19 Replies
- 2851 Views
Last post by prwood
- 1219 Views
Last post by Azik09
