Fog Light Not Working Topic is solved
Rucho26
Year and Model: 2004 S80
Has thanked: 6 times
Post by Rucho26 »
So I just recently discovered my rear passenger side fog light is not working (I'm pretty sure it was tho). I tried changing the bulb but it still doesn't work. When I press the button to have the Lights activated on the dashboard, only the left one on the rear side works.
Anyone have any ideas on how I could fix this?
Thank you.
Reason: Removed exclamation mark from title
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
You don't need to fix anything. There is only one rear fog light. Two rear fog lights would get confused for break lights.
Active
Past
Rucho26
Post by Rucho26 »
Thanks for the reply Rick. I'm 99% sure I saw them both work though.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
There’s only one.
Also -> Amazon link
Rucho26
Post by Rucho26 »
Thank you so much to both. I guess it is only one then. Ill stop tampering with that.
Id like to have both go on tho, not sure how to accomplish that.
kranz
Year and Model: '98 V70 NA stick
Been thanked: 8 times
Post by kranz »
I think it has been mentioned before that having more than one is illegal.
The rear fog light sees greater use in Europe. In northern europe during the winter nights the highways are frequently socked in with heavy fog. As one overtakes a vehicle in the fog, the single red light is the first sign that there is a vehicle ahead. Without it the vehicle is otherwise invisible as the tail lights don't penetrate the fog.
If you import a vehicle to Europe, if you don't have one you will need to install a rear fog light to pass inspection.
Les is more.
