Okay friends I need to change the thermostat on my 850 non turbo as the car isn't really blowing too much hot air except when I'm sitting still or when the engine is revving. So I'm thinking the thermostat is stuck open.
Well it's only two bolts right? No prob. Super easy. Except not. I cannot get the bolts to turn and I'm afraid I'm going to strip the bolts out. Any advice? I do have a massive impact wrench that I'm tempted to use.
Thermostat Replacement Advice
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I've heard of using a dremel with a cutting wheel to cut slits into the bolt heads for removal with a large flat head screw driver.
I do not think these are common bolts to snap, usually just strip the heads, so I would try the impact. But first, soak everything in your favorite penetrating oil. Also, you are 100% going to want new, quality steel bolts.
Knows enough to be dangerous
- callahanoffroad
Any idea what size bolts they are?WhatAmIDoing wrote: 17 Nov 2018, 16:05 I've heard of using a dremel with a cutting wheel to cut slits into the bolt heads for removal with a large flat head screw driver.
- Has thanked: 2212 times
- Been thanked: 1853 times
+ 1 on what the guys have said. I also have an elongated 3/8" Torx socket which allows the shaft to sit square against the side of the head. When I soak it with penetrating oil I use the Torx socket and give it a few taps with a hammer to try to shock the aluminum and steel threads to give a gap for the penetrating oil to work down.
Let is sit for 24hrs and tap again before trying to remove. I have a long 3/8" breaker bar and with as much downward pressure as possible, give it sharp tugs to try to break it loose rather than a steady pressure. To date have not stripped a thread or break a thermostat housing. Problem as usual is modern manufacturers using dis-similar metals which react and 'weld' to each others.
Good luck!
Good luck!
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
T40 long.
For a clean job the fuel line can be undone.
The torx head will likely strip. You will need two new screws.
- callahanoffroad
Good news fcp carries new ones ready to go.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Worst case scenario - I believe the whole housing can be removed from the engine. Obviously this too isn't fun...
2023 Lexus RZ450e -66k
- callahanoffroad
That's the, I'm taking my ball and going home scenario.wizechatmgr wrote: 17 Nov 2018, 18:41 Worst case scenario - I believe the whole housing can be removed from the engine. Obviously this too isn't fun...
- wizechatmgr
All else fails, cover half of the front of the radiator with cardboard until you can get it off - any heat that is more than you have will be heat you appreciate.callahanoffroad wrote: 17 Nov 2018, 18:44That's the, I'm taking my ball and going home scenario.wizechatmgr wrote: 17 Nov 2018, 18:41 Worst case scenario - I believe the whole housing can be removed from the engine. Obviously this too isn't fun...
I believe I shocked my bolts with a couple pound sledge on the end of a 3/8" extension before I removed them.
- 841 Views
Last post by oragex
- 3818 Views
Last post by oragex
- 2040 Views
Last post by F250
- 19 Replies
- 1944 Views
Last post by configsys
- 537 Views
Last post by Masscomguru
