Here's a new one - at least to me.
I stopped to check the oil in my 96 850 turbo sedan (~205k) this morning. When I pulled the dipstick I was horrified, because it looked like pancake batter. Knowing this was a sign of Serious Trouble, I called my mechanic to discuss and ask him to start working up the price for doing a head gasket. Before going there, though, the car was about 400 miles short of oil change time and I had some time, so I told him I'd get the oil changed and have the tech report on what, if anything, he might see that was out of the ordinary. I had changed over to synthetic this past summer.
The oil change tech reported nothing out of the ordinary other than the oil being "dark", consistent with 5600 miles out of a recommended interval of 6000. So I decided to drive around and called the mechanic to report what the tech had found and see when he'd be available for a couple minutes so he could look for himself.
An hour or so and 20 or so miles, mixed about 50-50 between surface streets and freeway, I was at the mechanic's.
We pulled the dipstick and saw the same pancake batter but also clear new oil at the correct level. On closer inspection, the thick goo was only on one side of the dipstick, AND it was all the way up the dipstick.
Looking down the dipstick tube we noted pancake batter-looking goo hanging onto the inside of the dipstick tube. It was getting scraped onto the dipstick as it went in and out.
Our conclusion was that "no, there probably isn't a coolant-oil mix going on" but other than that we're mystified.
Ideas on the cause? On how to clean it out of there?
Gunk in the oil dipstick tube
Dave in Maine
- Year and Model: 2009 S60 2.5T
- Been thanked: 3 times
1996 850 Turbo Gold Edition, 7 years' reliable service and >220k mi, sadly now gone
2009 S60 2.5T, sent away after taking me down Via Dolorosa. Happy to be rid of it.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Sounds like a mix of oil and water vapor being pushed up the dipstick tube by excessive crankcase pressure. A little bit of water in the oil from condensation and such is normal but as long as it stays in the oil it usually boils away.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
The "pancake batter" is EXTREMELY common. Like Rattnalle says, it's a mix of oil and condensation, forming as a result of the oil not getting hot enough to boil it off. This most often occurs when you take short trips only, not letting the engine heat up for long enough before shutting down. Take the car on a spirited drive for an hour or so, and like you saw, it clears up.
You can't clean it out, but should treat the symptoms just like you did. Do it at least once a week if all the car sees is short trips on most other days. Let it loose a bit as well, so you get it nice and hot.
(within legal limits, of course). Check your oil often, and a PCV overhaul might be a good idea if you haven't done that the last few years.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- June
- Has thanked: 523 times
- Been thanked: 261 times
If there is any water/ coolant in the oil it will also show up on the underside of the oil cap as a off white crud. Your mechanic could do a combustion gas test to the cooling system to properly rule out a head gasket leak. Because if it has a slight problem now it may avoid a all out failure potentially ruining the engine much less leaving you stuck with a tow bill on top of a replacement engine or car.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It's just condensation from frequent short trips in cold weather...don't worry about it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Just add syrup and butter and you are ready to go.
- misha
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Teddy1975
- Year and Model: 2007 V50
- Has thanked: 1 time
- Been thanked: 7 times
Actually, you can. The dipstick tube is removable and can be flushedSommerfeldt wrote: 21 Nov 2018, 11:53 You can't clean it out, but should treat the symptoms just like you did.
Whether it's needed or not, that's a different matter.
I've cut a length of pipe foam insulation and wrapped it around the dipstick tube. It seems to be working rather well in preventing condensation inside the tube, even with my many less than 10 miles per trip.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
Sommerfeldt
Well... yes. You can clean the tube and prevent just that spot from having condensation (mostly), but that’s not the only or probably even main place it occurs. As someone said above, you’ll also find it on the inside of the oil cap, signifying that it comes from and originated from somewhere else.Teddy1975 wrote: 21 Nov 2018, 13:31 Actually, you can. The dipstick tube is removable and can be flushed
It’s generally better to boil it off once or twice a week, so it doesn’t accumulate, at least.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 1205 Views
Last post by bmdubya1198
- 1045 Views
- 1158 Views
Last post by jimmy57
- 4062 Views
Last post by PapaNoni
- 5015 Views
Last post by JimBee
