2006 XC70. I never felt that this car had responsive brakes. Pedal has always felt low, meaning that I have to push down 1/2 way for braking to begin. Sometimes I think that after one pump, it is higher. Did a full brake/ rotor change, changed fluid...no change in feel. Am I missing something? or do these models have 'spongy' brakes? I have a 2013 S60, different feel. I have had 850's and S40...no issues.
What can I check or change to have more responsive, higher pedal?
Braking issues
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Are the brakes more responsive after the engine warms up? If that's the case test your vacuum pump and it's check valve switch using this thread as a guide
viewtopic.php?f=9&t=43817&hilit=cold+brakes
The 2007 XC70 I got last May had spongy brakes during startup until I replaced the burnt vacuum pump and check valve switch that was stuck open.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Try first the switch ($70 at Fcp euro). If the switch is working, with the engine off turn the ignition key to Pos II, then pump the pedal a few times: you should hear the pump buzzing to boost the vacuum.
zjevik
- Year and Model: S60 2006
- Has thanked: 1 time
I have 2006 S60 and there is no response the first 15% of the pedal travel. I changed the switch, brake booster, front calipers and lines for other reasons but the brake response stayed the same. I would say that the brakes are very gradual on my car but they do lock the wheel at 80%-90% of the pedal travel (especially after the front caliper replacement).
When my vacuum switch was not working the pedal feeling was almost the same but the "braking power" was way less if the engine didn't produce enough vacuum.
- 800 Views
Last post by wizechatmgr
- 18 Replies
- 3048 Views
Last post by volvolugnut
- 373 Views
Last post by 98S70T5
- 784 Views
Last post by krassigr
- 13 Replies
- 5466 Views
Last post by theobviousfaker
