Hesitation on WOT (V70 2.0 T5 AWD 1997) Topic is solved
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
Another topic today :)
I'm having an issue with a slight hesitation around 4500 RPM when going WOT in 2nd and 3rd gear (haven't had the opportunity to try in 4th and 5th haha).
Do you know how I should proceed to troubleshoot this issue ?
Thanks a bunch !
Edit :
I have replaced :
-Spark Plugs
-IPD HD TCV + the associated vacuum lines
-Distributor rotor and cap
I've never changed the fuel filter and I've been running E85 for 5000 km.
The car has 240000km on it
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Never replaced fuel filter for 240K km???
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Fiodor
Post by Fiodor »
Don't think so, I'm not the original owner but I couldn't find any trace of a change...
misha
Post by misha »
Hesitation at WOT could be from large vacuum leak.
What spark plugs did you use?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Fiodor
Post by Fiodor »
Denso IK20TT as some people in France suggested using Iridium Plugs in association with E85.
How could I go about finding a large vacuum leak ?
misha
Post by misha »
Turbo engines don't quite like fancy spark plugs.
You would need OE Volvo plugs (set of 5)for turbo engines or at least cheap Bosch or Ngk,single prong,properly gapped.
Gap is critical for turbo engines.
Don't be surprised if those iridium Denso are the source of your problems.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Fiodor
Post by Fiodor »
OK so I filled my tank with sp95 and nothing has changed.
In 4th gear it feels as if my acceleration is "toothed".
I'll try with OEM plugs as soon as I'm back in my city.
misha
Post by misha »
Before you start throwing money on blind...i would suggest to read the codes first.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Fiodor
Post by Fiodor »
I tried with a cheap obd reader and it didn't give me any codes.
misha
Post by misha »
Check engine light isn't ON?
No pending codes too?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
