Coil replacement Manufacturer?
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
Heh guys. Can anyone recommend a good coil manufacturer that won't cost me what I just paid at the Volvo dealer? ($113.00)
My V70 has 150k miles on her and the guy at the dealer just told me today that they usually replace all five (5) coils at once around 90k miles. Since I bought this car back in July, I have replaced Coil #4 and just today replaced Coil #1.
Also is this a task I can do myself? Thanks much!
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
I'd say dealer is exaggerating. Sure they can fail but not at a specific point like that and not so soon. Just get a (used) spare if you're worried another one will fail you.
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
Fcpeuro.com has a good price on Bosch(factory manufacturer) with lifetime warranty, so if they go bad free replacement. Cant be at that.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Has thanked: 1609 times
Been thanked: 4064 times
Definitely a DIY job, just unbolt and bolt.
FCP has them for in Bosch for $47
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
As mentioned, just an example (not necessarily your part no) https://www.fcpeuro.com/products/volvo- ... 0-30713416
Is it needed to replace all 5 ? Maybe at 150k is not a bad idea. These can fail all of a sudden and one must NOT drive the car with a misfire. However, as noted we can go with used ones as well.
Usually, there is a reason behind failed coils. Mostly worn spark plugs or top of the engine overly hot. Your n/a may need this www.youtube.com/watch?v=gOx3Q8vqoz4
Here's a few tips about the coils
www.youtube.com/watch?v=nDwtZCWU7u8
www.youtube.com/watch?v=uHLgXQo6E9c
Run to fail method....replace when you get the P030x code. You have to stop driving when it comes or else risk unburned gas ruining the cat.
Pm model, replace all 5 at 100 k miles. Recover cost of one selling 4 working ones on eBay, keep one in spare.
Mr. Detail
Thanks much everyone for your posts. I unfortunately still ran the car to work and back for two days (40 mile total) when it was misfiring. Hopefully I did not screw things up too much. Is the P030 code good for any of the five (5) coils? I had the plugs replaced with Bosch back in August when Coil #4 died and I have read comments that I should only replace plugs with OE Volvo ones.
As I look down into the engine compartment, facing the windshield, what is the # order of the coils? Is it a simple left to right, #1 thru #5 or some convoluted pattern?
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Mr Abscate -
100k, really. That surprises me. Compare to the life of an old style coil, which you rarely had to even deal with.
Can you do any multi-meter testing on your used ones to see which is the best to keep?
Been thanked: 504 times
Post by cn90 »
For my BMWs and Volvos I have at home, I simply go to junk yard and get a few OEM ignition coils as spare.
About $10/each.
BlackBart wrote: 25 Nov 2018, 17:23 Mr Abscate -
That's PM model, where you never experience failure. 5 coils is cheaper than the three distributor caps and rotors and spar plug wires you will go through on an older car.
I made and documented the resistance measurements but they fail to open suddenly , I think.
You only need the working one to last the time you get a free replacement from FCP, of course.
Anyone caught buying one then using the free policy to get the next failure free will have a delta link tool put up their backside, or a red hot dipstick used as the old Syphillis cure
