Did you know? 🤔
2001 V70XC - Leak at radiator hose to thermostat Topic is solved
2001 - 2007 XC-70
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 21 times
Been thanked: 42 times
United States of America
xHeart
Post by xHeart » Sat Dec 01, 2018 8:31 am
190,000+ miles. The task to remove and install radiator is not difficult. The two replaced in our '87 850 & 2013 XC90 were Volvo.
I found radiator made by Nissens, Behr, and TYC. I stick to Volvo for critical functions and 100% out-of-the-box fit. But happy to take your recommendation for a best match.
Happy Holidays.
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +196mi/ +315km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
Has thanked: 337 times
Been thanked: 1043 times
Trinidad & Tobago
Re: 2001 V70XC - Leak at radiator hose to thermostat
Post by abscate » Sat Dec 01, 2018 3:25 pm
Just make sure the radiator is mounted solidly and the engine mounts are solid. Engine torque on the radiator snouts will break the plastic side tanks from the metal radiator seal in short order. Mine took only 3 years
Link To Volvo Glossary
boostedxc
Year and Model: 2004 XC70
Has thanked: 0
Been thanked: 0
boostedxc
Post by boostedxc » Sat Dec 01, 2018 7:40 pm
I got an extra OEM one that will fit your car I'd sell for cheap. let me know if you're interested. [email protected]
xHeart
xHeart
Post by xHeart » Mon Aug 26, 2019 1:32 pm
Small coolant lose. I am noticing coolant residue just below the upper trans-color line. The rubber hose below that is connected to condenser is wet from the drip.
This is a persistent slow leak since the install -- replacement Volvo radiator pn 31319056.
xHeart
xHeart
Post by xHeart » Sun Oct 06, 2019 6:44 pm
The coolant escapes at the reservoir overflow nipple. Every few weeks the level drops to min. Blue/Green residue collect at the reservoir seam. Is the hose failing?
Found wetness and crystalized residue at the connection, the clamp is at max. Is the hose failing or the reservoir cracked?
Trinidad & Tobago
Post by abscate » Sun Oct 06, 2019 7:21 pm
Probably cracked reservoir. I remove it and inspect under bright light
reverend
Year and Model: 2006 V70 2.5t
Has thanked: 0
reverend
Post by reverend » Thu Oct 10, 2019 7:34 pm
You can cut off the 'molded' end of the hose that connects to the overflow jar, then push it back on and snug it back up.
xHeart
xHeart
Post by xHeart » Fri Oct 11, 2019 1:47 pm
This is original hose -- maybe dried and hardened. A good weekend for this maintenance.
xHeart
xHeart
Post by xHeart » Mon Oct 21, 2019 7:38 am
Cut off 1" from the bleeder hose at the reservoir and reconnected. The wetness was visible at the either end of the bleeder hose, reservoir and radiator respectively.
xHeart
xHeart
Post by xHeart » Tue Dec 03, 2019 9:36 am
This thread is reverted to UNSOLVED since the slow escape of coolant continues.
What's best type of hose to purchase from the auto parts store to replace the bleeder hose -- ID, material, etc?
