1999 V70 multiple error codes, bad B+
Dodgertom
- Year and Model: 1999 v70 xc
- Has thanked: 2 times
I've a 1999 volvo v70 xc. Drove it to Farmers' Market, and all was well. Started it up again, and the idle was high, and the car was running rough. It threw 7 engine codes and 1 transmission code. The engine codes were throttle unit communication, speed signal, ecm communication, throttle position signal, accelerator position signal, ecm communication, and control module communication. The tranny error code was control module communication. Does anyone know if there's a connector where all these come together? I hope it's something simple such as that. Thanks.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Sounds like a power supply issue. Check your battery cables.
- Been thanked: 4064 times
You need to clear all these codes and see how they come back.
Also, you need the Volvo ECM codes , not the generic descriptions
Dodgertom
Thanks abscate. What I didn't say (trying to be brief) was that after jiggling some connectors (and the two computers), the symptoms went away. I have cleared the codes, but the symptoms haven't returned yet. I will check the battery connections in the morning. The jiggling and the array of codes was what made me think connector.
The codes were: ECM-902a, 510f, e000, 903f, 959f, 912a and 530b; plus tcm-e000. After a while it added TCM-261a, the long-term fuel trim. Thanks again, I appreciate your feedback.
Dodgertom
Found some (only a little) white corrosion on the positive battery terminal. Cleaned it off, and have not had the codes return. Didn't realize that such a small amount of corrosion would interfere with the electronics. Thanks again to abscise and rspi for your help.
Thanks for the follow up!
- 11 Replies
- 3705 Views
Last post by gcb50
- 1262 Views
Last post by ThreeEleven
- 1944 Views
Last post by Addswing20
- 3632 Views
Last post by Rob2016
- 2252 Views
Last post by apwbee
