change your oil regularly, folks!
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
And a question - what's the bottom of the PCV channel in the oil pan supposed to look like? It's clogged on mine, so I've got it soaking in acetone. Where is it supposed to drain into the pan? At the bottom?
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Maybe s/he did change the oil regularly, but with Wallyworld supertech dino oil. And by regularly every 10k miles.
Knows enough to be dangerous
- Has thanked: 312 times
- Been thanked: 818 times
That channel in the block continues into the channel in the oil pan, which makes a 90˚ turn at the bottom of the sump. So it looks like you have the pan off and the answer to your question is a simple "yes."
For the record, I swear by SuperTech DexIII (dino) for all of my P80 cars. It's the only thing I've ever used in them. I do keep it clean.WhatAmIDoing wrote: 01 Dec 2018, 21:11 Maybe s/he did change the oil regularly, but with Wallyworld supertech dino oil. And by regularly every 10k miles.![]()
- Has thanked: 1611 times
- Been thanked: 4073 times
Mike posted a trick about clearing this port by ramming plastic tube into the gunk and then cutting the end off each time it plugged until you worked it through once the passage is open. You can gun brush it and then run multiple oil changes to get the rest of the crud out.
dobrosailor
- Year and Model: 2002 Vovlo C70
- Has thanked: 5 times
I just went through this nightmare on my V70 pulling the pan, luckily my engine was pretty clean inside. I am going to Synthetic oils as this Volvo notice suggests. even the box could be cleaned out - didn't have to replace it. I have to say Castrol GTX green kept this motor very clean over the 50k I've run this motor but I'm taking Volvo's advice here...
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Jaysus, the pictures in that thing are nightmare fuel.dobrosailor wrote: 03 Dec 2018, 04:44 V70, Lubrication System Contamination Cleaning.pdf
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
I'm a little unclear on the path of the oil sump port. The document shows the port is a 180 degree trap, where does the external port connect to that port exactly?
The lower port for the oil trap is in the engine block. That channel connects at 90˚ to a vertical channel in the block, which connects to the square channel in the top of the oil pan.
Is that what you're asking?
- 25 Replies
- 2550 Views
Last post by 454cid
- 1100 Views
Last post by chrism
- 463 Views
Last post by Trossard
- 432 Views
Last post by dikidera
- 11 Replies
- 16078 Views
Last post by RossJonnes
