Engine crash
So my 2012 S60 with 93K miles just an engine crash -- serpentine belt broke and apparently got sucked into the timing belt, which caused the valves and cylinders to crash. Dealers says that it would cost $7,800 to repair, Volvo only willing to "contribute" $2,000.
precopster
- Year and Model: Lots
- Been thanked: 128 times
It sucks to have a newer car with this problem. Sorry to hear it.
If it were serviced by dealers and they didn't catch the bad tracking while engine running it would be somewhat their error, however they can only see 10% of the belt's area upon visual inspection with engine off.
You may be better off with a used engine and an indie repairer to fit it, financially speaking.
Is that a new engine Volvo propose to fit?
- June
- Has thanked: 523 times
- Been thanked: 261 times
The serpentine belt wraps around and behind the crankshaft balancer crushing the timing cover taking out the timing belt in the process. According to my service advisor your era 5cyl engines should have the serpentine belt tensioner changed with every timing belt service as the tensioner has a high failure rate. I know this because I have heard her talk to several customers over the last couple of years recommending the tensioner be replaced. Junejlh3rd wrote: 04 Dec 2018, 19:24 ?..I didn't know the timing belt is exposed. I have a 2012 s60t5. Just curious how this could happen.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Yeah, if I'm going to fix it, it won't be at the dealer because of the cost. An engine replacement would be even more expensive than the $7.8K, which is basically to replace the pieces that crashed into each other, some of the cylinders and valves
- June
According to my dealer to put a new engine out of the box will cost $12,000.00 for my S80. I imagine a 5cyl would be about the same price range. But that does come with a lifetime parts and labor warranty. JuneJanJM wrote: 04 Dec 2018, 19:49 Yeah, if I'm going to fix it, it won't be at the dealer because of the cost. An engine replacement would be even more expensive than the $7.8K, which is basically to replace the pieces that crashed into each other, some of the cylinders and valves
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- 2160 Views
Last post by theWIFES_S70
- 3457 Views
Last post by volvolugnut
- 6164 Views
Last post by MadeInJapan
- 1068 Views
Last post by mark0006
- 3398 Views
Last post by ctramp
