I have a '99 V70XC, it has 200k miles.
The bevel gear whines. Changing the oil didn't help. I don't know the current part number. Where is it located?
Located a good used angle gear for a reasonable price, but it's from a 1998 V70 awd. That part number is P9183972.
I know there's differences in flange sizes, and from what I've read they can be swapped, correct?
Are there any other differences?
My v70xc is a late '99 (VIN YV1LZ56K8Y2661331)
Thanks for any insights.
Joost
Will a '98 angle gear fit my '99 V70XC?
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
There is a VIN brake in mid 98', from which point on the AWD is the same as 99'.
I will try to dig that up, I know I have a document somewhere that describes this.
Dirk
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- 850 LPT
I can't find the information on the VIN break anymore.
But, the part number for a 98' -99' angle gear is 8602679. That is the one I bought from Volvo a few years ago for my late 98' V70XC. That car was manufactured AFTER the VIN break and it is shared with 99'. So this one would be a direct fit for yours.
I don't know about the one you saw from the 98' AWD. I suspect it might be one from before the VIN break and would not fit. I will keep digging for the VIN break, I know it's in my e-mails somewhere...
Hope this helps,
Dirk
Hope this helps,
Dirk
13' Honda Odyssey
13' Honda Odyssey
- jvl
- Year and Model: 2006 V70 2.4D
- Has thanked: 20 times
- Been thanked: 8 times
Again, thanks much for looking this up, I will not proceed then unless I can get more certainty on the vin break.
This is all good info and helps me in my search.
Please let me know if you run into the e-mail about the vin break? The seller is parting out a car so I think I can get the VIN belonging to this angle gear from him.
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
- 850 LPT
The last 6 digits in model year 98 must be higher than 465001. I gleaned this info from SS, you can read through this thread for more info:
https://forums.swedespeed.com/showthrea ... +VIN+break
Hope this helps,
Dirk
Hope this helps,
Dirk
13' Honda Odyssey
13' Honda Odyssey
- jvl
Great! Thanks!
Based on the info from the topic you linked to, I've asked the seller for the VIN number and a picture of the flange and hope it turns out to be the right angle gear.
Let’s put both part numbers and the VIN break info into this thread once done for searchability
( that’s a note to myself)
- jvl
Yeah, I also like to close the loop on threads for future readers but I haven't heard from the seller yet.
Will keep you posted Steve!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I was in that same situation a few years ago and may have documented that VIN break on one of my videos. I was given a VIN breat that was NOT correct. It was several hundred off. I did end up getting an angle gear that worked. My mechanic had to swap the cone over from one to the other.
