Hey, folks! I bought a 2004 S80 2.5T with 100k miles on it from the estate of a neighbor who passed away - she was original owner with very detailed service records - about a month ago. I have loads of euro tools from my Benz (totaled from Hurricane Michael) and am pretty handy. I've noticed there's a serious lack of performance parts that are specific to the S80, but NO shortage of parts for the 2.5T powerplant. I've already BSR tuned it, but have a set of "R" exhaust manifold to toss on and a 16T turbo with billet wheel to throw on, as well, when the weather warms up.
The problem I'm running into comes from the turbo back - I'm not finding any reasonable exhaust options besides custom. Has anyone taken a S60 or V70 2.5T downpipe and tossed that onto an S80 chassis? I still haven't crawled (creeped) under the car yet to check out exhaust paths. But, I wanted to ask y'all to see if anyone has gone this route before I seek out a custom-fabricated exhaust. Also, what mufflers are popular with this type of engine? Most of my experience is with V8's, so I'm not sure what muffler option would go well on a 5 cylinder turbo motor. I love the vehicle so far, it's super low-key and has great potential to hurt some feelings/surprise some folks during my commute.
Parts Compatibility - Downpipe
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
Yep fits, just make sure that its for a FWD (not AWD), if its a angled flange and you are all set. I couldnt find a proper downpipe for my S80 2.4T, but doublechecked with BSR and they confirmed it should fit (which it does
Hahah nice to see I have the same planning (also 16T with R manifold).
BSR 3" Downpipe with Sports Catalyst by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- ndphotonl
Stock vs BSR 3"
Volvo S80 2.4T 3" BSR Downpipe by Andy Ramdin, on Flickr
Downpipe in place
Volvo S80 2.4T BSR 3" Downpipe + New Catback by Andy Ramdin, on Flickr
Looks familiair
16T with R manifold.
Volvo S80 2.4T TD04HL-16T + Upgrade Exhaust Manifold by Andy Ramdin, on Flickr
Volvo S80 2.4T 3" BSR Downpipe by Andy Ramdin, on FlickrDownpipe in place
Volvo S80 2.4T BSR 3" Downpipe + New Catback by Andy Ramdin, on FlickrLooks familiair
Volvo S80 2.4T TD04HL-16T + Upgrade Exhaust Manifold by Andy Ramdin, on FlickrVolvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- ndphotonl
Im currently in the process of buying a 3" stainless exhaust, my main criteria was that it needed to be stealth, like the OEM exhaust. The only one I found so far is this one from Sweden:
http://www.a-alt-avgassystem.se/3-tum-r ... -turbo.htm
The Simons one looks likes it needs a cutout of the bumper, although not sure.
FlickR images
FlickR images
Stark77
- Year and Model: 2004 S80 2.5T
- Been thanked: 2 times
Wow - thanks for the quick reply! Once the weather warms up, I hope to get all of this installed into the car (going to check PCV as well, but records show it's been serviced within the last 10k miles). I need to get the inside of the R manifold cleaned up, it came off a salvaged S60R with over 100k miles and the carbon build ups are THICK! Will you be swapping injectors?ndphotonl wrote: 06 Dec 2018, 12:04 Stock vs BSR 3"
Downpipe in place
Looks familiair16T with R manifold.
- ndphotonl
Yes I will, but I dont know yet if I need the white, blue or green ones.
350cc (white) bosch partnr 9454557 - 98 T5 models
395cc (blue) bosch partnr 9186060 - 99+ T5 models
465cc (green) bosch partnr 9202100 - S60 R
[edit]
I would advice to check it, for peace of mine.
I was tipped of by this when I swapped the stock intake pipe with a silicone version. I then checked & serviced the PCV...
Volvo S80 2.4T Dirty Turbo Coldside by Andy Ramdin, on Flickr
...And then I found this
Volvo S80 2.4T PCV Repair by Andy Ramdin, on Flickr
[edit]
Volvo S80 2.4T Dirty Turbo Coldside by Andy Ramdin, on Flickr...And then I found this
Volvo S80 2.4T PCV Repair by Andy Ramdin, on FlickrVolvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
Stark77
Wow, that’s a huge amount of buildup! Had you been using synthetic or conventional oil?ndphotonl wrote: 06 Dec 2018, 13:58 Yes I will, but I dont know yet if I need the white, blue or green ones.
[edit]
- ndphotonl
I always use synthetic. I dont know what has been used before I owned the car.
FlickR images
FlickR images
Stark77
This car is fairly new to me (about 6 weeks), but as soon as weather improves, I'll be swapping fluids - from looking at the dipstick, I believe that my car was given to me with conventional oil. Amsoil replacement ASAP! Also, 3" downpipe ordered - thanks for the assist with the information on that!ndphotonl wrote: 08 Dec 2018, 08:34 I always use synthetic. I dont know what has been used before I owned the car.
- ndphotonl
Awesome!
Removing the old one takes quite some time as you have to remove a small bracket, unclip the lambda sensors. Also double check that the new downpipe has an extension cable delivered for the second lambda. The position of the second lambda is usually in a different place, which then requires an extension cable.
I just received my first CEL due to the catalyst flowing too fast for the second "control" lambda. My 2 cents, buy a lambda spacer immediately so this issue is solved. I will mount it when I mount my catback, for now I just clear the code every now and then.
Either one will do:
Either one will do:
FlickR images
FlickR images
