any ideas? I;m looking at a 1997 850R that supposedly had the original motor swapped with a low mileage 2.3
are there external cues that are obvious or do i need to find stamped numbers etc..
thanks
850r with replaced motor. how to id if motor is a 2.3 or 2.4
- RickHaleParker
- Been thanked: 979 times
Get the engine family ID off the engine block.
Active
Past
Past
- RickHaleParker
It is stamped on the block, behind the timing firewall side.
It can be hard or impossible to get your head where you can see it. I power wash the block on that side then use a mirror to read it or stick my phone down there and take pictures, then read it off the pictures.
Active
Past
Past
