New spark plugs and wires...Thanks
Fistom
Year and Model: xc90 2010
Post by Fistom »
I recently replaced the spark plugs and spark plug wires https://mechanicfaq.com/spark-plugs-for-5-3-silverado/ on my xc90 2010, on the way to autozone (approx. 4 miles away) to get my refund back for the warranty, the engine started a pulsing shake only when I idled in the parking lot. I knew it was a misfire and immediately thought I inserted the plug wires wrong. I took all 8 out and plugged them back in but it didn't help. I read the code P0300 which said 1 or multiple misfires,also a fuel pump code. I already had codes for my fuel pressure sensor, and knock sensor(which i was trying to avoid till I could afford it). The engine shake has progressively gotten worse to the point where I feel it while accelerating, and driving at a constant speed(losses power). My question to all of you, is what could cause a misfire after replacing spark plugs correctly? Could it be the fuel pump/pressure sensor causing the misfire? Or is it the coils? Is there a way to narrow down which cylinder is misfiring before replacing a bunch of other things? I just need the misfire gone so I can gradually fix the little issues. Any comments will help me greatly. I'm out of options other than replacing the fuel pump and hoping that's the main cause.
Thank you for your time:)
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
Which engine on your XC90? When you talk about "...took all 8 out and plugged them back in..." it suggests a V8, but the Volvo V8 has individual coil packs, no plug wires, so it's a little ambiguous. Plus, you included a link to a Chevrolet Silverado, which suggests you have a Chevy, not a Volvo. Anyway, did the Check Engine Light come on? Were you able to pull any trouble codes? Trouble codes will often point to which cylinder was misfiring, which might help you to narrow it down. I would definitely troubleshoot a bit more before going straight to "replace the fuel pump" - see if you can figure out what the problem is before randomly throwing parts at it.
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
