I'm an owner of a '99 V70. A friend of mine is wanting me to look at a 2006 V70 N/A 2WD A/T with 240k kms. Any advice on what to look closely at? Weak points? future maintenance/repair issues likely? THANKS!
Also any good Volvo repair shop recommendations near Markdale - (between Shelburne and Owen Sound area in Ontario Canada)?
My wagon and my eager passenger ...
Looking at 2006 V70
voltech1
- Year and Model: 2000 V70R
- Has thanked: 2 times
Make sure the timing belt has been done. Check the transmission fluid condition. After a test drive leave the car running and check the oil dipstick tube for pressure or smoke. The intake camshaft seals like to pop out of place getting into this mileage. Front control arm bushings are common wear items. About the same as your current vehicle with more electronics that could possibly fail. Less than an AWD model. If it is kilometers do you say mileage?
96 855 turbo 235k
00' v70r 156k w/blown motor
Shappy
- Year and Model: V70 1999
- Has thanked: 5 times
If I'm discussing the number of kilometers with someone in USA I usually convert it to miles. For example 244,000kms converts to 151,280 miles. (0.62 X # of kms = # of miles, approx.).
When test driving the car a check engine light appeared that turned out to be P0026 Intake Valve Control Solenoid Circuit Range/Performance Bank 1. So we're having that solenoid replaced.
- 1079 Views
Last post by oragex
- 888 Views
Last post by volvomadness
- 545 Views
Last post by benpineapple
- 713 Views
Last post by Polestar
- 3388 Views
Last post by David+Son
