740 Cam Pulley Removal
waynegarbo
- Year and Model: 86' 740 non-turbo
- Has thanked: 2 times
How do you leverage off the cam Pulley bolt? I tried using a wrench but can't stabalize the pulley.
waynegarbo
with impact tool, do you gradually throttle the switch?93Regina wrote: 17 Dec 2018, 22:49I would leave belt on, and try a Karate chop on a 1/2" breaker bar. But, use your palm
I use impact tools, so this is not an issue
waynegarbo
ok great. now, when putting the pulley back on, should I snug it, then put the belt on, then tighten it? do you worry about torquing the bolt?lummert wrote: 18 Dec 2018, 12:23 Use the longest 19 mm (3/4 inch) box-end wrench you can find and smack it with a hammer. Doesn't need much of a smack from the hammer.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Bolt requires about 37 ft-lbs torque....In your situation, I'd install timing belt, then maybe have someone hold cam with vise-grips clamped between two holes, so that a downward force would be used to hold...palm on top side of vise-grip...pressing downward..waynegarbo wrote: 18 Dec 2018, 15:20putting the pulley back on, should I snug it, then put the belt on, then tighten it?
IIRC, another way, take the old timing belt, wrap it around the cam's teeth, then vise-grip both ends of timing belt; if vise-grip is on left side, and wrench is on right side, one can exert downward force on both sides. Myself, I don't use a torque wrench since 37 ft-lbs via 1/2" break-over bar is something I have a feel for. YMMV.
A person could fabricate a counter-hold tool
waynegarbo
Two things: vice grip all the slack, then anchor the belt with my left hand? wouldn't a shorty wrench counter leverage with my right hand since my left is not able to help?
- 93Regina
37 ft-lbs torque - Generally, one uses a smaller length 3/8" ratchet, and its a firm pressure...YMMV
Yes, grab the slack, then clamped down vise-grip....both hands are pushing downward....been there, done that.
waynegarbo
on un unrelated matter, I scratched the fuel ports on top of another fuel pump sender I'm putting in. will the hoses still seal?
- 1419 Views
Last post by XC70Rider
- 30 Replies
- 5788 Views
Last post by mrjay62
- 1011 Views
Last post by 98v70dad
- 2443 Views
Last post by andreivlas
- 466 Views
