Quick and dirty things to look for on a 2004 XC70
volvooh
Year and Model: '98 S70, '05&'08 V70
Been thanked: 4 times
Post by volvooh »
Looking at an '04 XC70, 130,xxx mi. Need to find out when timing belt service/water pump was done, because its more than due if it hasn't.
Any other issues such as water incursion (might be an '05 thing), transmission (thought after 2002 they were ok). If I get it I'd like to use it for occasional short distance towing for small trailer, jet ski- like that.
I have an '05 V70 that has served us well. (and a 98 V70 and 99 S70)
Abscate, any issues with the ECU on these? :D
Any input is appreciated!
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Definitely glove test for PCV condition. Pull transmission dipstick and smell for burnt fluid/check color. You want to see some cherry red. If chocolate brown, plan on a transmission fluid swap. Check for leaking power steering fluid reservoir. They leak from the cap, but they also leak from the seam between the upper and lower halves of the reservoir. Those are just a few quick ones.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1609 times
Been thanked: 4063 times
That's just mean.
There was a water incursion TSB on the 2005 for the CEM bulkhead through the dash, not sure if it caught the 2004" too.
E Showell
Post by E Showell »
Probably a little late for the original poster, but check the front coil springs. They are prone to failure (as in snapping). My one and only (so far) long distance tow was due to a snapped spring. ETM can also fail, but due mostly to dodgy wiring.
'95 855 auto (sold)
