Cold Start ok, almost stall during warm up, then fine when warm
pdr1966sc
Year and Model: 2006 V70R
Been thanked: 2 times
Post by pdr1966sc »
I've seen similar symptoms but not a clear solution:
06 V70R - just been through Timing Belt, PCV, struts, radiator.......
If it is a few degrees below freezing - cold start is fine - but once the engine tries to slow and idle down (after about 1 min) it almost stalls, recovers, and almost stalls - does this for a few minutes until the engine is warmer, once fully warm it is just fine.
I have VIDA, and may try to observe fuel/02's but have not actively run vida this way yet.
Kind of tricky to trouble shoot because after it is warm, the symptoms are gone.
Also not a lot of fun booting up the laptop to watch in the morning when you are trying to get somewhere.....
Any suggestions appreciated.
93ForMe
Year and Model: 1993 850
Been thanked: 17 times
Post by 93ForMe »
I know that this was posted a while ago, but did you ever find a solution to this problem? I am having a similar problem with my 93 850.
Thanks!
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
sounds like the ETM to me?..there is a test on VIDA
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
93ForMe wrote: 17 May 2020, 17:38 I am having a similar problem with my 93 850.
When was the last time you cleaned the idle control valve?
Active
Past
93ForMe
Post by 93ForMe »
I cleaned my idle control valve a couple of weeks ago, still having the problem.
This is my situation:
viewtopic.php?f=1&t=93975
