94' Volvo 855T P0131 after a new O2
- henrysin44
- Year and Model: 1994 Volvo 855 Turbo
- Has thanked: 2 times
- Been thanked: 3 times
I replaced my O2 sensor about 10,000mi ago, but recently the car started running pretty poor with bad MPG again. I unplugged the MAF sensor and the code went from P0131 to the absent MAF sensor code so I swapped MAF sensors with one from a junkyard and the car ran fine for 2 days with no codes but now the P0131 is back. I have a hard time believing the new O2 sensor is bad, anything I should look for? I've already checked for vacuum leaks and the wiring to the sensor looks fine.
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
- Has thanked: 1613 times
- Been thanked: 4075 times
Unless you removed and replaced every vacuum hose , don’t rule out a vacuum leak.
Smoke test is best, remove and replace takes longer but is sure to find and fix any leaks
- henrysin44
I actually did, elbows an all, even a new throttle body hose.abscate wrote: 24 Dec 2018, 10:08 Unless you removed and replaced every vacuum hose , don’t rule out a vacuum leak.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
What condition is flexy pipe?
It can disturb front o2 if it's cracked.
Generic o2 sensors will not work...usually.
You need oem Bosch with OE connector.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- henrysin44
The flex pipe is in pretty poor condition (missing the crosshatch cover) but i couldn't feel or hear any exhaust coming from it, the sensor is OE Bosch. When I view the freeze-frame data it says heated catalyst N/A, I don't know if that means O2 heater absent or no CAT. It is cat-less with a flashed ECU to ignore the rear O2.misha wrote: 24 Dec 2018, 12:26 What condition is flexy pipe?
- misha
Rear o2 on '94?
Are you sure?
Are you sure?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- henrysin44
Yeah VIN and documentation says 94' but it has OBD I and II, and had a rear O2.
I'm now getting P0131 and P0172, the codes are pending codes none have set MIL to ON. But while driving ill randomly smell rich fuel and see my MPG drop but then go back to normal, it seems like a wiring issue and with the P0131 should I be looking into the wiring of the O2.
- misha
P0172 is usually a vacuum leak.
Car is running rich.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- henrysin44
I don't want to jinx it but I think I've solved the problem, The O2 sensor connector had water and oil in it so I cleaned and dried it out, there was also an extension connector for the O2 so I removed that and plugged it straight into the main connector. After driving it a bit the codes went away.
If not then I suspect the intercooler could be leaking as everything that air passes through was replaced a month ago, I have a spare from a 2000.
- henrysin44
It rained a lot yesterday and I drove through minor flooding and now the P0131 and P0130 are back, I cleaned the sensor out again but this time added dielectric grease inside the connector, but the code comes back (as pending) after a few miles of driving. It runs fine, great throttle response, constant idle, and MPG around 30 according to the computer. But the second P0131 sets the MIL i get poor MPG and runs terrible.
I've checked for vacuum leaks but the car doesn't feel like it has one and I've never seen a vacuum leak throw a P0131.
- 1419 Views
Last post by henrysin44
- 768 Views
Last post by misha
- 416 Views
Last post by Sveedy
- 2273 Views
- 841 Views
