Merry Christmas -- I have a 1991 940 T Volvo that just died while I was driving. AAA came to give me a jump, but it wouldn't take a jump ended up having to tow it home. Cars turns over, just won't start.
Any thoughts would be greatly appreciated??
Car dies while driving
- RickHaleParker
- Been thanked: 977 times
Give it a 3 second shot of starting fluid, see if will fire.
Active
Past
Past
940tvolvo
- Year and Model: 1991 Volvo 940turbo
- Has thanked: 1 time
Okay thank you I will give that a shot. Question though, could it be my timing belt? I have never had a timing belt go out on me so I have no idea of what it would do if the timing belt went.
940tvolvo
Is there anyone in Portland, Oregon who would be willing to give this single women a helping hand look at my car. I have no money to offer, but i do have cords of wood. I am at a loss and really need my car up and running. Thank you
- RickHaleParker
It could be a slipped timing belt. Take the plastic cover off the top of the engine and press down on the timing belt. If it is loose it could be a slipped timing belt.
Do you know how many miles have passed since the last time the timing belt was replaced. Your suppose to replace timing belts at regular intervals ... one should never wait until a timing belt goes bad.
Active
Past
Past
940tvolvo
I do not know when it was replaced last. The odometer has been broke since I've owned the car which is 4 years. So it has been at least 4 years. The car turns over just seems like there is no spark.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
If the timing belt has broken the engine will turn over like it has no compression. Once someone has had this happen they know what it is next time it happens.940tvolvo wrote: 29 Dec 2018, 21:42 I do not know when it was replaced last. The odometer has been broke since I've owned the car which is 4 years. So it has been at least 4 years. The car turns over just seems like there is no spark.
1988 Volvo 760 Turbo Wagon
940tvolvo
So my roommate took one of my spark plugs out and touch it to something to see if it was getting a spark and had me turn the car over, he said it was getting a spark, so the timing belt was good. I check fuse 1 and 11 they are good. ???
- RickHaleParker
You can still get spark with a slipped timing belt. Note: I said slipped, not broken.
Active
Past
Past
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
You can also get spark with a busted dowel-pin on cam sprocket....which is not the same as a slipped timing belt. Volvo's B23F engine has this issue...I know, first hand.RickHaleParker wrote: 06 Jan 2019, 00:44You can still get spark with a slipped timing belt. Note: I said slipped, not broken.
- 1774 Views
Last post by oragex
- 994 Views
Last post by virginiavolvolover
- 1033 Views
Last post by precopster
- 19 Replies
- 3923 Views
Last post by cn90
- 19 Replies
- 5279 Views
Last post by Eliotlm
