Yesterday I was replacing brake rotors and pads on our 2004 XC70. I do one corner at a time and realized that both rear wheels could spin freely. I did notice recently that my front wheels would freak loose quite easily on gravel but didn't put it together. I hear no noises and have no CEL
Edit;
I should have mentioned that I can't turn rear driveshaft/propshaft by hand, so I'm assuming it's something in the rear.
2004 XC70 AWD not working
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
precopster
- Year and Model: Lots
- Been thanked: 128 times
That's not a lot to go on. Best to scan with Vida. If DEM (AWD controller at rear axle) is offline the CEL isn't lit in any case. If the hydraulic pump has failed the result is the same as a failed DEM.
There are AWD tests you can perform. It's best to search here for the actual operational tests for the rear axle.
- shiloh51933
My apologies....precopster wrote: 26 Dec 2018, 05:51 That's not a lot to go on. Best to scan with Vida. If DEM (AWD controller at rear axle) is offline the CEL isn't lit in any case. If the hydraulic pump has failed the result is the same as a failed DEM.
If the pump or DEM has failed I still shouldn't be able to move those rear wheels if the other 3 are grounded right?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The AOC AWD system is not active without engine running. The hydraulic pump is not turned on until the engine running data bit is broadcast on network. If you do the same things with eng running and you do not have considerable effort to turn the wheel then there is a problem. The AOC will have a low clutch apply pressure when you are doing the test so you could turn the wheel if you apply enough force to exceed clutch load.
You can also do a very quick trst to see if there is a DEM (awd controller) code(s) by having engine running and then hold the READ button on end of turn sig lever and then push the rear fog light button twice. Then the display in cluster will show checking and then likely "DTCs IN VEHICLE" Then pushing the READ button will scroll through the list showing "xxx CHECKING", "xxx READY", or 'XXX DTC SET". checking means it has no DTC but the diag sequence is incomplete, usually has to be driven for this to turn to READY. Ready is no dtc set. You can't see what the code is but if it has no DEM DTC then the temp/pressure sensor is not faulty. No dtc doesn't mean you are in the clear as the coupler sleeve between trans and the angle gear that drives rear driveshaft could be worn out and the spin by hand
- shiloh51933
It says "DEM not checkedjimmy57 wrote: 26 Dec 2018, 10:15 The AOC AWD system is not active without engine running. The hydraulic pump is not turned on until the engine running data bit is broadcast on network. If you do the same things with eng running and you do not have considerable effort to turn the wheel then there is a problem. The AOC will have a low clutch apply pressure when you are doing the test so you could turn the wheel if you apply enough force to exceed clutch load.
CEM dtc set
DDM DTC set
CCM dtc set
PDM dtc set
PSM dtc set
SWM dtc set
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Check the fuse by the rear hatch.shiloh51933 wrote: 27 Dec 2018, 05:59It says "DEM not checkedjimmy57 wrote: 26 Dec 2018, 10:15 The AOC AWD system is not active without engine running. The hydraulic pump is not turned on until the engine running data bit is broadcast on network. If you do the same things with eng running and you do not have considerable effort to turn the wheel then there is a problem. The AOC will have a low clutch apply pressure when you are doing the test so you could turn the wheel if you apply enough force to exceed clutch load.
CEM dtc set
DDM DTC set
CCM dtc set
PDM dtc set
PSM dtc set
SWM dtc set
- shiloh51933
You think I need one?
- shiloh51933
Fuse is good.jonesg wrote: 27 Dec 2018, 13:43Check the fuse by the rear hatch.shiloh51933 wrote: 27 Dec 2018, 05:59It says "DEM not checkedjimmy57 wrote: 26 Dec 2018, 10:15 The AOC AWD system is not active without engine running. The hydraulic pump is not turned on until the engine running data bit is broadcast on network. If you do the same things with eng running and you do not have considerable effort to turn the wheel then there is a problem. The AOC will have a low clutch apply pressure when you are doing the test so you could turn the wheel if you apply enough force to exceed clutch load.
CEM dtc set
DDM DTC set
CCM dtc set
PDM dtc set
PSM dtc set
SWM dtc set
- shiloh51933
I was able to get some more information concerning AWD issue.
E000- Control module Communication faulty Communication.
0065- Stop (brake) lamp switch signal outside range.
0103-Pedal Position sensor faulty signal.
0147- Pedal Position sensor signal outside its permitted range.
So it looks like something with the CEM is failed up. Any suggestions?
- 942 Views
Last post by jaces_dad
- 366 Views
Last post by deedee
- 1590 Views
Last post by darylrobert
- 22 Replies
- 13875 Views
Last post by XC70Rider
- 5263 Views
Last post by THeOldMan
