anyone have a problem with c70 flashing stc lamp with spare tire mounted
hightech24
Year and Model: 2003 C70 convert
Has thanked: 1 time
Post by hightech24 »
i have a 2003 volvo c70 and have a flashing stc lamp with spare tire mounted, what can cause this
Has thanked: 1613 times
Been thanked: 4078 times
It might be the difference in size between the tires and small spare is enough to trigger the wheel speed difference parameter in software - have a look in the owners manual to see if this is the case?
You can turn off STC with the button if it is coming on all the time`
speed limit with spare is 50 mph, are you going over that?
hightech24
Has thanked: 1 time
no it triggers at 25 MPH and puts the car in a low power mode and i cant go higher than 30 MPH
Check that your spare is identical in size to the stock one - size is in the owners manual, of course.
Also, I presume you are running the spare on the back and not the front.
hightech24
Has thanked: 1 time
the tire was on the front and it is the original spare size, i just shut of the TCS as recommended and it worked
