Voltage for fuel injectors
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
Hi all, I have managed to source a set of used fuel injectors for my 98 S70 (Bosch 0280155766). I want to do a full clean and backflush on the bench before attempting to install them as I have no idea what kind of condition they are in. Do these run at a full 12V in the vehicle or is it a stepped down voltage? The last thing I want to do is fry a solenoid
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
- misha
- Has thanked: 155 times
- Been thanked: 432 times
12v ,battery voltage...or 14.4v(while engine is running).
You can't run them constantly with power source of 12v...you will need the switch for opening and closing them...to imitate ecu controller(about 2 times/second).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
shegarty
Thanks for the info. I plan to just use an old battery on the bench and pulse it by hand, from what I have seen on the interwebs this should be fine for very short periods.
- misha
Just keep the battery and pulsing away from fuel and vapors...long wires would be a MUST...and well ventilated area.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 891 Views
Last post by kensington1
- 5555 Views
Last post by hans747
- 1583 Views
Last post by 93Regina
- 1317 Views
Last post by RussB
- 12 Replies
- 6789 Views
Last post by Wykis
