2002 V70 X/C alternator output Topic is solved
- Mike Langlois
- Year and Model: 2002 V70 & V70 XC
- Has thanked: 28 times
- Been thanked: 6 times
Anyone know how many amps a 2002 V70 X/C alternator outputs? Installing an aftermarket stereo and may need a little more output.
- RickHaleParker
- Been thanked: 977 times
They are not all the same, 120A, 140A or 160A depending on the options the car came with. You need to get the numbers off the alternator to determine which one you have.
Active
Past
Past
- Mike Langlois
Just what I thought; took a quick look and did not see numbers on the first go around..
- RickHaleParker
Might be hard to see in the car. Often molded on the back cover in non-contrasting colors.
Active
Past
Past
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Try sliding a camera and take a macro of the regulator, some of the numbers should be apparent, then check the FCP site
jimmy57
- Been thanked: 322 times
The amperage will shown as somethig like, "70 ->120". The low number is the output at a standard alternator RPM for engine idle speed and 120 is max rated.
Kraig
- Year and Model: 2003 XC70
- Has thanked: 5 times
How can one tell if their current alternator was replaced with one of the right size? How would one go about confirming their current alternator is indeed correct one? Is there a way the VID gets used to find out option package?
- 15 Replies
- 2698 Views
Last post by thefisch
- 593 Views
Last post by Herb Goltz
- 1128 Views
Last post by DeeSi
- 18 Replies
- 4185 Views
Last post by skloon
- 1045 Views
Last post by carboncow
