Lost my brakes after hitting deer
A deer and I had a run in. I won but she destroyed my driver front head light assembly and crinkled hood slightly. At time of impact ABS engaged, car stopped but when I went to pull to side of road I had no power brakes at all. It is like I am driving a vehicle with manual brakes. No fluids leaking, a few wires in that corner under hood have damage. I will investigate more today. Could it just be a sensor or am I looking at booster issue or are there vacuum lines I should check? Thanks!
- Been thanked: 4064 times
Probably damage to the vacuum " ejector" or hoses , not hard or expensive to fix
Venison, mmmmmmmm, when is the roast?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, pop the hood and look behind the headlight, you got the brake booster vacuum pump below, the switch at the top (most probably broken), plus some vacuum hoses around - mark them so you know which goes at which side of the switch. The hose at the pump has a green clip that may detach/break
https://www.fcpeuro.com/products/volvo- ... o-31265825
- 91 Replies
- 11053 Views
Last post by mrjay62
- 24 Replies
- 2412 Views
Last post by TisMe
- 1979 Views
Last post by PeteB
- 804 Views
Last post by c70_lindsay
- 1694 Views
Last post by oragex
