D4204T5 Camshaft Timing
Pecan60
Year and Model: 2014 xc60
Post by Pecan60 »
Hi, I 'm new here but hope you can help.
I have a 2014 uk spec XC60 with 2.0 D4204T5 engine (vea engine) and have to replace the timing belt due to contamination from an oil leak from the oil pressure relief valve above the crank seal being loose!!
I have removed the crank pulley and can see the crank timing mark but can see no mark or way of locking the camshaft.....the cam sprocket has elongated bolt holes for adjustment. Surely the camshaft has to be locked in position?
I can find no info on the web regarding this.
Regards, Paul.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
See the attached file.
D4204T5_Timing_Belt.pdf
(612.59 KiB) Downloaded 3654 times
Active
Past
Pecan60
Post by Pecan60 »
Thanks RickHaleParker,
Excellent info.
The only slight difference is on my cambelt sprocket the holes have adjustment just like the injection pump sprocket, but without a lock pin location at the camshaft hub.
I wonder whether I shoud tighten the camshaft sprocket in its previous fitted location or centralise it in the elongated holes.
Thank you again
RickHaleParker
There is a Camshaft alignment tool (Volvo part number 999 7007 (a guide pin)) that inserts in to the rear of the engine. This locks the camshafts in position. From there you would align the the timing marks on the sprocket, this would align the sprocket to the cams.
It looks like you can get the guide pin at a Volvo Penta (marine and industrial) supplier for ~€38 -40.
A full alignment kit on eBay uk for £35.10.
Active
Past
Pecan60
Post by Pecan60 »
Thank you Rickhaleparker, that makes much more sense now. Pain having to take the vacuum pump off to get to it though.
Thanks again.... great forum guys!
jurmala2004
Year and Model: 2015 V70
Post by jurmala2004 »
Hello,
Could anyone upload the timing belt replace manual again? The file does not exist anymore.
Engine D4204T5
RickHaleParker
jurmala2004 wrote: 10 Jun 2019, 02:14 Hello,
Engine D4204T5
(612.59 KiB) Downloaded 2479 times
Active
Past
jurmala2004
Thank you so much!
