Did you know? 🤔
Clicking driver's side door module
2001 - 2007 XC-70
mrjay62
Year and Model: V70XC 2002
Has thanked: 0
Been thanked: 3 times
United States of America
mrjay62
Re: Clicking driver's side door module
Post by mrjay62 » Mon Feb 18, 2019 5:02 pm
Ok... I had the same issues on my 02 V70 xc 1st the driver side would click for an hour or more than start working again, I pulled it, cleaned all the switch contacts seemed better for a while then the passenger door started to do it no windows no locks,no temp sensor.
I took a shot and went to a junk yard and found the same model and year I pulled both modules and installed them in my car. It's 2 months later and so far no problem. Not bad for 17$
dlundblad
Year and Model: 2002 S60 2.4t
Has thanked: 6 times
dlundblad
Post by dlundblad » Tue Feb 19, 2019 1:40 am
Not bad at all. Thanks for the info.
Hers: Charcoal 2002 S60 2.4t 187k
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 22 times
chrism
Post by chrism » Tue Feb 19, 2019 9:43 am
Here are a couple links to previous DDM problem posts. One even describes the clicking and battery going dead:
viewtopic.php?t=26624
viewtopic.php?t=23510
If there is a a small white label stuck on the module with numbers on it, (not the part number molded into the plastic), that's the key to the castle. In my case there were three numbers on the label - the replacement module matched the first two numbers out of the three. It ended up working fine with no reprogramming required.
Jonboy74
Year and Model: V70 2.4T, 2002
Has thanked: 30 times
Jonboy74
Post by Jonboy74 » Sat Jul 27, 2019 9:43 am
dlundblad wrote:
Tue Jan 08, 2019 4:09 am
Is the door chime silent too?
I know this is 7 months late...apologies...
Honestly, I had not given it any thought, so I just went out and checked. If the key is in the ignition, and the door is open, I get a chime. Pull the key out or close the door, and the chime stops.
Thanks,
Jonboy
mrjay62
Has thanked: 0
mrjay62
Post by mrjay62 » Sat Jul 27, 2019 4:22 pm
Best bet is to find another car same year,model. Grab them disconnect your battery and swap them... I was charged 9$ for the drivers side and 8$ for the passenger side at a U pull it yard... And it's still working! Since then I found another set and bought them ... For Just in case.
Test them before installing on to your door panel.
Good luck....
Jonboy74
Jonboy74
Post by Jonboy74 » Wed May 13, 2020 11:00 pm
For anyone reading this, for what it is worth....I chatted with Yagger in July of 2019 and ended up buying a replacement DDM off of ebay for under $60, matching the numbers on my module with what was on the one on ebay. Worked like a champ without any programming, and seems to have been working fine for the most part ever since. Occasionally the window seems to be stuck, but flipping the switches back and forth seems to un-stick it.
Cheers!
Jonboy
darrylrobert
Year and Model: 2001 v70xc
Has thanked: 3 times
Been thanked: 7 times
Australia
darrylrobert
Post by darrylrobert » Sat May 16, 2020 7:41 am
I had the same issue, i tried replacing the little relay in the module but it kept playing up. Ended up buying a replacement online and that fixed it.
Sometimes when i press auto down either window will get about half way down stop and go back up, might be getting stuck or might need to re learn where up and sown is..not sure
