Did you know? 🤔
1999 S70 NA “Lady Evita” AT Base 019 Stone Black 3580 Cetus 15 wheels
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Has thanked: 356 times
Been thanked: 1094 times
Trinidad & Tobago
Re: 1999 S70 NA “Lady Evita” AT Base 019 Stone Black
Post by abscate » Thu Jun 27, 2019 7:59 pm
Front right caliper running hot , 300 F after hard stop
Removed and cleaned caliper slide pins. Rust removed with drill press and sandpaper , greased with antiseize
Link To Volvo Glossary
Trinidad & Tobago
Post by abscate » Sat Jun 29, 2019 3:31 am
Right front caliper sticking , 158111
Cleaned caliper pins
viewtopic.php?f=1&t=90075
Trinidad & Tobago
Post by abscate » Sat Jul 06, 2019 3:31 am
No start, battery dead
Left door open on hot day, new battery for winter planned
Charged at 10,amps
Replaced positive battery cable, cut old one at harness and starter, routed new one on parallel course
Replacement part from FCP does not have boss on terminal to connect harness loom, will put an M6 nut to compensate.
Replaced fan hardware with stainless 3/8 by 1.5binch hardware from Lowe’s for four fan screws and two upper radiators screws
Evan put a new radiator in in 2017-25.... yeah!
Trinidad & Tobago
Post by abscate » Mon Aug 05, 2019 4:04 am
159900 replaced cooling group hoses
Upper rad hose
Lower rad hose
Upper heater hose
Lower heater hose
Water pipe to reservoir hose
Reservoir to radiator hose
All new clamps, closed tipe
PEX on heater and end of water pipe hose
Radiator has 1;4 turn lock and pull type stopcock
New Volvo coolant after 30 minute flush
Replaced loom on ECT wire
2october2019
New Advance 3year Gold battery , old one not holding starting charge longer than one week (5 years old)
Current drain on Main Fuse 6, Circuit 7 - shows about 250 mA draw
Abby will pull main fuse six when car sits for more than a day or two. We will find drain on semester break in Fall
viewtopic.php?f=1&t=91400&p=522058#p522058
Trinidad & Tobago
Post by abscate » Sat Nov 16, 2019 11:06 am
Changed oil filter 160314
Trinidad & Tobago
Re: 1999 S70 NA “Lady Evita” AT Base 019 Stone Black 3990x Cetus 15 wheels
Post by abscate » Thu Dec 26, 2019 7:23 am
Dec 25 160600
Replaced chattering purge valve with new from FCP
Trinidad & Tobago
Re: 1999 S70 NA “Lady Evita” AT Base 019 Stone Black 3580 Cetus 15 wheels
Post by abscate » Tue Dec 31, 2019 3:08 pm
2020 maintenance records
Thought I had solved the electrical gremlin when I disconnected passenger door and normal function was restored. Two days later, problem reoccurred. I suspect the NPN power transistor inthe 2/76 has faulted to drain and will try a board level replacement.
Swapped snows April 1. Notice oil seep fro crank or cam area , to be evaluated.
Oil seep April 20
Oil seep April 20
Popped a fronT OXS heater failure code. Part 9125583 , will check wiring and stash
Replaced front OXS , cam intake oil seal , 164500
10 May. Removed dash, rebuilt mounts, fixed cracks, rebuilt foot panel mounts, wired in usb to top dash, usedJB weld clear quick set epoxy. Nice stuff, minimal out gassing.
15 July
Replaced exhaust cam seal, slight seep
