Im trying to free up a white block NA which has a stuck piston number 5.
Does anyone have an image or diagram of which piston is where during the crank pulley cycle?
Im hoping the piston is stuck mid stroke so I have a better shot of popping it free without breaking a ring.
P80 engine crankshaft diagram - where are pistons relative to the timing mark?
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Would it be helpful to measure the depth of each piston via the spark plug holes?
No coolant use reported by PO and oil clean and non-milky. Piston not looking any cleaner than others
All signs point to no coolant in cylinder'
Im using a ATF acetone MMO mix in cylinder 5
I can't believe I didn't think to use Pooh sticks to measure piston position - apparently I am a Bear of Little Brain
Number 5 is stuck mid stroke - SWEET!!
This engine freed up after three days and is now happily powering around Abby in her black S70, named Evita
- 417 Views
- 979 Views
Last post by bmdubya1198
- 1351 Views
Last post by Ozark Lee
- 2724 Views
Last post by Williamad33
- 589 Views
Last post by oragex
