Short crank
836howard
Year and Model: 2005 xc70
Has thanked: 1 time
Post by 836howard »
I bought a 2005 xc70 with a blown motor. Mechanic replaced motor but cant get it to start it will only roll for half a second if i go from off to roll position. Then stops cranking. I do have an immobilizer message but i dont know why it qould crank at all if it was the immobilizer. Need suggestions thanks
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Turn key on, pull the starter motor relay and jump terminals 3 & 5, See if it will do a long crank.
Active
Past
836howard
Has thanked: 1 time
Post by 836howard »
Okay we will try that and see what happens
836howard
Has thanked: 1 time
Post by 836howard »
If i jump 3&5 it will crank all day but no fire also we did notice there was no power to the ecu fuse
836howard
Has thanked: 1 time
Post by 836howard »
RickHaleParker
1. Put the relay back in.
2. Get in the car the lock/unlock the door 5 times in a row with the remote.
3. Try to start car.
Active
Past
836howard
Has thanked: 1 time
Post by 836howard »
We did try that still nothing
