IPD sale Volvo Parts
2001 V70XC - Random stall when coming to a stop... Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
xHeart
Year and Model: 1997 854 NA
Has thanked: 7 times
Been thanked: 17 times
United States of America
Post by xHeart » Tue Jan 08, 2019 6:34 pm
Would servicing fuel rail result in air pockets in fuel injection?
Recent maintenance https://www.matthewsvolvosite.com/forum ... =9&t=61449 included replacing fuel filter, servicing fuel rail and replacing injector o'rings. Surge was present few times as if there was ghost on gas pedal.
Is there a procedure similar to those after steering fluid, trans fluid, and coolant?
Golden Retriever | 2014 VIDA DiCE | 2013A XC90 +130kmi/210kkm | 2001 V70XC 1st Owner +190kmi/ +305kkm | 1997 Volvo 850 NA (2.5L/5) Sedan 1st Owner +172kmi/ +277kkm
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
XC70Rider
Year and Model: 2007 XC70
Been thanked: 9 times
Re: 2001 V70XC - Random stall when coming to a stop...
Post by XC70Rider » Tue Jan 08, 2019 9:12 pm
No service necessary when messing with the fuel rail. The fuel pump will exclude air within a few seconds.
Since you cleaned the PCV system I would check for vacuum leaks. Hook up VIDA and search for DTCs and the AFR.
xHeart
Post by xHeart » Thu Jan 10, 2019 9:40 am
No CEL at this time, but orange triangle has lit up with message "Engine Service Required".
Debugging VIDA/DiCE.
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 147 times
Been thanked: 440 times
Trinidad & Tobago
Post by abscate » Thu Jan 10, 2019 10:20 am
That little idle wobble Is typical of a vacuum leak somewhere.
The other horrifying possibility is I believe you are blessed with the sexy MM Italian throttle body
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
xHeart
Post by xHeart » Thu Jan 10, 2019 11:00 am
There is/was a wobble, idling near 700RPM mark.
It is sexy and clean MM. I removed it to clean and replaced gasket. Carefully compared gaskets before putting new on.
Does it mean running an ETM test once (insert F word here) VIDA/DiCE get with the program?
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 19 times
Been thanked: 11 times
Post by EngineeringBloke » Thu Jan 10, 2019 2:15 pm
2001 MM ETMs were troubled. The resistive track that is used to report where the throttle plate is positioned would wear over time. When the throttle was in common positions, those positions would wear more.
When the engine computer could not see the throttle position, it could shut down the throttle which is very dangerous, if you were trying to turn left across traffic and the engine suddenly slowed, for example.
https://www.matthewsvolvosite.com/forum ... hp?t=17252
Xemodex repairs/replaces them. Hope it is something else as this is not the cheapest part.
Trinidad & Tobago
Post by abscate » Thu Jan 10, 2019 3:16 pm
You get about 10,000 miles of warning before it goes to limp mode.
If you drive around with ECM throttle body codes and/or ETS lights on, that’s your warning.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
xHeart
Post by xHeart » Sun Jan 13, 2019 7:34 pm
The original MM was replace around 146,000 miles. This is yellow label.
At surge while idling the angle goes above 7.xxº, then it drops to following. It does not stall but struggles a little while idling.
Trinidad & Tobago
Post by abscate » Mon Jan 14, 2019 4:47 am
Was the ETM new or used? The yellow labels fail exactly the same as white, so if it's coming up in 125k it's due again.
That throttle angle seems low for idle, I thought mine sits at 5-8%
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
xHeart
Post by xHeart » Mon Jan 14, 2019 8:09 am
Unless we've more data from others, a 5-8º will be around 1500RPM. Our XC70 always idles between 640-680RPM.
ETM was new this time five years ago (Jan 2014) , so it now has 44,000 miles on it.
While live, throttle angle hovers little above 2.xxº in my situation.
Unless there is more under ECM, I'll capture live ETM data on all parameters and share it.
Who is online
Users browsing this forum: Brentscrazyptwo, dhollow2, EngineeringBloke, Shanestrait, XC70Rider and 61 guests
