IPD sale Volvo Parts
Micro switch shift lock override
enotslim
Year and Model: 1998 V70 T5T
United States of America
Post by enotslim » Tue Jan 08, 2019 9:58 pm
1998 v70 t5t requires shift lock override button to leave park. I dissasembled and tested the switch manually. Sometimes it works, sometimes not. When not i can usually jump the switch terminals and the solenoid works. Everytime i reassenble the switch and solenoid it does not work. Could be intermittent switch failure. Before replacing switch should I check anything else? Other likely causes of this failure? Solenoid and brake switch clearly work. But so does the microswitch ... some times.
Now:
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
enotslim
Re: Micro switch shift lock override
Post by enotslim » Sun Feb 17, 2019 6:32 pm
Well, I replaced the microswitch and the solenoid mechanism works. I can shift out of park without using the shift lock override button. However, I can't make the new microswitch fit the available space. But no problem - now instead of using the override button I simply reach into the exposed center console and squeeze the microswitch. Works every time. It's pretty hilarious.
It doesn't fit because the wires are enclosed within a plastic barrier. See photo. I noticed this when the switch arrived but assumed it was OK. It's not. I'm considering removing the barrier (crushing it) and hoping the wires fit when exposed (just like the original). Could be removable protection but it's stuck on there pretty tightly. Returning doesn't seem worthwhile or likely even possible after installing.
Am I missing something here? Am I missing how to make it fit? Does this switch fit other Volvos and/or is it the wrong part? Purchased here: https://www.ebay.com/itm/122986088414. What's the point of a barrier given the original microswitch on this car lasted over 20 years without one?
Another thing: when removed both the old and new switches "worked" as judged by continuity testing but only the new one would activate the solenoid. I didn't measure the resistance of the old switch. Maybe I will but without removing the new switch to compare I might not be able to interpret the result.
Now:
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
enotslim
Post by enotslim » Wed Feb 27, 2019 4:39 am
After removing the plastic barrier (another use for Vice-Grips crush) and wrapping the exposed electrical elements with electrical tape (see image below, before and after Vice-Grips and before wrapping) the switch installed and works fine - just to close this thread. May not be "permanent" (nothing is) but short-term success became a goal in itself. Presumably this protective plastic works in some vehicles. It did not in mine.
Now:
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 10 times
Been thanked: 7 times
Austria
Post by hausmeister » Wed Feb 27, 2019 4:58 am
Hope you re-soldered that black wire.
s70 '98 2L na manual Image || 850 T5-R '95 auto Image
enotslim
Post by enotslim » Wed Feb 27, 2019 5:11 am
I intentionally did not re-solder. It's more secure than it appears in the photo and an awkward position in the garage is a no soldering zone, at least for me, at 2 am. If it fails I now know what to do. Exposing the area only takes a few moments.
Now:
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
Who is online
Users browsing this forum: No registered users and 69 guests
