IPD sale Volvo Parts
P2 Volvo Multiple Misfire Diagnosis
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
mlc611
Year and Model: 2006 Volvo XC70
United States of America
Post by mlc611 » Wed Jan 09, 2019 11:01 am
My 2006 XC70 was running really rough after a period of storage. Mechanic put in 5 new spark plugs, and new coils on cylinders 1 & 5.
That helped a lot, but it's still running rough. It throws a code for Cylinder 3 misfire. Later, it throws codes for Cylinder 1 Misfire and "random multiple" misfires.
When I unplug the wires to the coils one at a time, with the engine running, I notice a change in performance for each coil except for #3. That is, when I pull the wire on #3, the engine noise doesn't change at all whereas when I pull 1, 2, 4, and 5, it alters the tone or stumbles for a moment.
I'm going to start by replacing coil pack #3 (and maybe 2 and 4 while I'm at it).
But what I'm trying to understand is whether a faulty coil on #3 could cause the misfire code on Cylinder #1 (which already has a new coil pack). Or is there likely to be a secondary issue? The codes were cleared multiple times and problem reoccurs the same way each time.
Suspecting a vacuum leak, I tried pulling off the vacuum lines at each engine port I could find and plugging them with a thick rubber sheet. Plugging each one did not fix the rough idle. I don't think it's a vacuum leak though since the problem persists under hard acceleration, and I think vacuum leaks issues typically go away under high rpms....
Any other ideas?
Thanks!
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 117 times
Been thanked: 382 times
Trinidad & Tobago
Re: P2 Volvo Multiple Misfire Diagnosis
Post by abscate » Wed Jan 09, 2019 1:48 pm
Unlike GrandPas Volvo, unplugging coils to diagnose is not healthy for transistorized ECU fired coil packs.
Definitely replace coil pack 3, but first move a couple of packs around to see if the running fault follows the coil.
Plug it in, start it, shut it off, unplug, restart. Look up the cost of an ECU if you think that is too much work - don't forget to add a couple hours at the dealer for software
The cylinder misfire locator is not foolproof and the rougher the car runs, the worse it is.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
mlc611
Post by mlc611 » Wed Jan 09, 2019 5:42 pm
That's really good to know, thanks.
I'm afraid that if I looked up the price of an ECU replacement, I'd probably sell the car.
Trinidad & Tobago
Post by abscate » Wed Jan 09, 2019 7:34 pm
They almost never fail. There are a slew of them on eBay gathered from junkyards by people who sell them for Tunes.
From 1999- on, they are married to the car VIN so you can't just plug them in without software work
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
Who is online
Users browsing this forum: dj_v70 and 43 guests
