When I accelerate there's a rumbling noise from front left corner and when going over wavy parts in the road it's worse but going over the same wavey parts (coasting) at same speed but with the clutch down, there's no rumbling!
It's not wheel bearing and the engine mounts don't seem to have split. It's a 92 940 gle not turbo.
Any suggestions as to what it could be?
Front left noise Topic is solved
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
Really need some more info.
Stomp on brake while stopped and then hit gas while drive selected. Can you duplicate noise?
If not, accelerate from a full stop. What speed does noise start? If you accelerate from 0 to 60mph, does noise occur during full acceleration.
Pyrinex
- Year and Model: 1992 940
- Has thanked: 1 time
Dj, it's manual but with handbrake up and front wheels chocked I could give it gas and let clutch up, I can see where you're going with this- as the engine twists it will lift the engine mount? I'll give it a go as I've only tried pushing the engine over by hand to see if it's split.
I will give you're idea a go too. There's a strap on the mount too so I'd think the sound would be traveling through that if the rubber is split.
Cheers for that.
Cheers for that.
- 1806 Views
Last post by MrPc
- 949 Views
Last post by jbeebo
- 482 Views
Last post by mtd240
- 2284 Views
Last post by GazmorGuri75
- 436 Views
