Alternator - 120A, 140A, or 160A? Topic is solved
Jonboy74
Year and Model: V70 2.4T, 2002
Has thanked: 119 times
Been thanked: 15 times
Post by Jonboy74 »
How do you figure out which alternator came with your car ORIGINALLY? Is there some way to tell based on the VIN? I'm not 100% convinced the one installed is the correct one....and it is failing.
Thanks,
Jonboy
Has thanked: 1609 times
Been thanked: 4065 times
Try putting your VIN into the Volvo parts Lisle website and see what comes as " standard"
Jonboy74
Post by Jonboy74 »
Thanks. Tried that. Got all 3 options. πŸ˜‚
https://parts.volvocarslisle.com/a/Volv ... nator.html
Jonboy
dlundblad
Year and Model: 2002 S60 2.4t
Has thanked: 6 times
Been thanked: 4 times
Post by dlundblad »
Which one do you currently have?
The 160A should be about the same price as the 120A. Nothing wrong with moving up either.
Hers: Charcoal 2002 S60 2.4t 187k
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
The biggest one is always safe if price differences aren't too big. The only reason there are options is to save money when making the cars.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Car being the 2002 ? I think you could put any of these. Perhaps if the car had the radio amp then maybe the alternator was upgraded, but I think early years got either 120 or 140. I wouldn't worry much, just look to get a real Bosch unit, even a used one with a good pulley clutch. What is really important is to stay with 2001-2003 or even better 2001-2002. Somewhere in 2004 the regulator was modified and while it does charge on a 2001-2003, the voltage may not go higher than 13.5V which is not enough and will chew the battery after a few months. You need to see something like 14.5V after starting the car, then drops to 13.5V once the battery is full.
The replacements has 160amp for all years, but seems it doesn't have clutch pulley ? https://www.fcpeuro.com/products/volvo- ... 0a#fitment
A 120A version with clutch pulley https://www.fcpeuro.com/products/volvo- ... 0a#fitment
A 140A with clutch pulley https://www.fcpeuro.com/products/volvo- ... 0a#fitment
Jonboy74
Post by Jonboy74 »
Thanks guys!
Goodnight everybody. ;-)
Jonboy
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The 160A one in FCP photo has a freewheel pulley also. I see the black painted and the cadmium plated ones with the smaller caps on Volvo OE replacement ones. The black and cadmium ones both will have INA on the pulley. I'm inclined to think the cad plated may be higher capacity pulley
oragex
Post by oragex »
Makes sense, I was thinking too all 2001-2009 should have the clutch pulley, thx!
