IPD sale Volvo Parts
Change Automatic Tranny Fluid Ya or Nah
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
Rattnalle
Has thanked: 10 times
Been thanked: 78 times
Sweden
Re: Change Automatic Tranny Fluid Ya or Nah
Post by Rattnalle » Sat Jan 12, 2019 3:14 am
Did Aisin really tell them it was sealed for life though? Saab for example used the same transmission but kept oil changes in the prescribed service.
Year and Model: 1999 V70T5, 2005 V70
Has thanked: 117 times
Been thanked: 382 times
Trinidad & Tobago
Post by abscate » Sat Jan 12, 2019 4:18 am
My BMW X3 ( GM transmission) has a sticker on it next to the drain plug saying “ lifetime transmission oil, do not change” or something like that. I put a little black dot on it every two years when I draw out 3 liters and replace with fresh
Realistically, they are sealed for life of the first owner ( typically 7 years here) and the next owner ( typically 3 years)
After that, the auto industry doesn’t care. Next set of owners are cheapskates who re-use engine oil.
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
ignatz
Year and Model: 2002 V70t
United States of America
Post by ignatz » Sat Jan 12, 2019 5:20 am
98 S70 T-5
Georgeandkira
Year and Model: 2007 V70 base
Been thanked: 25 times
Post by Georgeandkira » Sun Jan 13, 2019 7:36 am
Remember, 1) "people posting failures bias" as well as 2) careless do-it-yourselfers using the wrong fluid PLUS 3) people performing fluid refreshments well into their transmissions' sickness and 4) myths formed back in the early days of automatic units where the gunk actually did help seal things up, all combine to create a landscape of fear.
I've drained fluid from these transmissions a lot of times. A few times the fluid was jet black and once the fluid was brown and lumpy-truly hideous.
Nothing but improvements realized, so "Ya" is the answer for the Ontarian.
24mm wrench....18mm aluminum crush washer....Any cheap funnel with a foot long extension of clear plastic hose.
I like the Poland Springs 3 liter bottle for measuring what drains. They're all over the place and you can discard them when finished.
shiloh51933
Been thanked: 5 times
Post by shiloh51933 » Sun Jan 13, 2019 11:10 am
If the service history of said vehicle is unknown then a fluid flush is usually taken off the table. Draining the old fluid by way of pan drain plug is fine. If your already experiencing issues with shifting then doing nothing can only lead to failure . I'd do a few drain and fills over the next few weeks. Just make sure you use the proper fluid recommended by the manufacturer. Personally I use "Aisin Warner " ATF Type T-IV or "Mobil 1" JWS 3309, the Aisin Warner is on sale at FCPEURO.COM for like $6 bucks for 1liter.
If U Wanna Play U Gotta Pay!!
MDK
Year and Model: 1998 xc 70
Been thanked: 9 times
Post by MDK » Sun Jan 13, 2019 12:27 pm
If it is an Asin-Warner trans. Idemitsu is the original fluid. Not the over priced relabled 'Volvo" fluid. FCPEURO had fluid available on their website for 6.50 a quart. I personally would get 12 and disconnect the top line from the radiator and let the tranny pump it out into a 5 gallon there is a drain plug on the bottom and always fill through the dip stick tube. Very important. Follow the instructions from the YouTube channel mentioned in this blog. MDK
dlundblad
Year and Model: 2002 S60 2.4t
Has thanked: 5 times
Been thanked: 3 times
Post by dlundblad » Mon Jan 14, 2019 3:11 am
We did a cooler line flush on her S60 around 155k or so. Used 14 quarts of Toyota T-IV ($3.50 a quart from the dealer) and have been very happy with the results since.
Hers: Charcoal 2002 S60 2.4t 187k
Archer
Year and Model: 2006 V70R
Post by Archer » Mon Jan 14, 2019 5:26 am
+1. Idemitsu for sure, perhaps 14 - 16 quarts for good measure. Lubegard (red) Protectant is supposed to be a very good addititive, too. Also, make sure you check the fluid level after the car has been driven a while.
Who is online
Users browsing this forum: No registered users and 53 guests
