IPD sale Volvo Parts
2000 Volvo S80 Key won't turn
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
UHBlackhawk
Year and Model: 2000 S80
United States of America
Post by UHBlackhawk » Fri Jan 11, 2019 12:45 pm
I've tried turning the steering wheel, but that no longer works.
I took off the ignition and am able to start it using a screwdriver, but I can't get it out of gear.
I've seen videos where they remove the ignition lock and then "jury rig" the steering wheel lock. But none of the videos show you how to remove the ignition lock. It seems like there are two bolts holding it in place, but nothing seems to fit them. Do I have to drill these out?
RickHaleParker
Has thanked: 2 times
Been thanked: 227 times
Re: 2000 Volvo S80 Key won't turn
Post by RickHaleParker » Sun Jan 13, 2019 8:51 pm
Look close at the top of the bolts. I'm sure you will find they been broken off. Most Ignition Lock Cylinders are installed with security bolts. I'm pretty sure Volvo used Socket Shear Bolts where the Socket head shears off when it is tighten and torqued. You do need to drill out a Shear Bolt to remove it.
Socket Shear Bolts will shear at the thin part when torqued.
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Who is online
Users browsing this forum: No registered users and 13 guests
